Re: 73 Challenger, need Ignition switch and lock cylinder
[Re: 318 Stroker]
#2348976
08/05/17 02:36 PM
08/05/17 02:36 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Switch... 70 and laters
Cylinder, 71 and laters... 70 and some earliers 71 got a diff locking setup on collar for the cylinder
Need to note several replacement switches are made now to match several setups, so will need to match your one ( remove one extra black wire they got for example your Chally doesn't use ). Some manufacturer include instructions sheets, but some others not.
[Re: 318 Stroker]
#2349454
08/06/17 01:41 PM
08/06/17 01:41 PM
NachoRT74
Valencia, España
Here is ( for example ) one ign switch with instructions sheet, made for several diff 70s setups. https://www.oldsobsolete.com/products-pa...rg-warner-cs82/Good priced if you ask me BTW! If you get it, get the instruction sheet scanned of pictured for tech references around! ( send to me LOL ) Several replacement switches got a diff rivets disposition on backelite, maybe due the extra functions like the think black wire mentioned ( which I have no idea of year and apllication ), but fits and works the same on steering column collar ( EDITING: nevermind, says out of stock )
