Motor mountsg block truck? #2348893
08/05/17 12:13 PM
08/05/17 12:13 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I have a pair of motor mounts I am trying to ID. I believe they are for a big block truck?
Re: Motor mountsg block truck? [Re: GKMOPAR] #2348932
08/05/17 01:21 PM
08/05/17 01:21 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Common design for the 70' and 80's in trucks.
The mounts that I have, including those still attached to a '76-77 B engine, show a slot that is right close to 2" in length on both pieces.
Cannot find any A-LA mounts right now.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: Motor mountsg block truck? [Re: GKMOPAR] #2349850
08/07/17 12:54 AM
08/07/17 12:54 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The difference between the small block mounting brackets and the big block mounting brackets is the distance between the holes for the mounting ears at the motor. The mounting ear holes on a big block are farther apart then they are on a small block.
In the picture, the bracket on the left appears to be a small block bracket, and the one on the right appears to be a big block bracket. Gene
Re: Motor mountsg block truck? [Re: poorboy] #2349877
08/07/17 01:43 AM
08/07/17 01:43 AM
I never woulda guessed. Sometimes it ain't what you know its WHO you know!
Re: Motor mountsg block truck? [Re: poorboy] #2350233
08/07/17 06:27 PM
08/07/17 06:27 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Shouldn't both mounts be slotted? The one on the left lacks the slot. I've never seen that before.
Re: Motor mountsg block truck? [Re: GKMOPAR] #2350439
08/08/17 12:52 AM
08/08/17 12:52 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The sandwich rubber mounts with the interlocking feature usually have the brackets with the hole and the nub to orientate the rubber mounts correctly. Guess that was probably cheaper the punching the slot. Gene
Re: Motor mountsg block truck? [Re: poorboy] #2350446
08/08/17 01:00 AM
08/08/17 01:00 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
iagree
Those are 1972-80 2wd and 72-74 4wd.
May be the same as 81-93 2wd???
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Motor mountsg block truck? [Re: GKMOPAR] #2350473
08/08/17 01:40 AM
08/08/17 01:40 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Thanks for the information. It does look like one of each. The slotted one is about 2 1/2" inside to inside and the other is about 3". Not sure how I ended up with that? Anyone need a mis-matched pair of motor mounts? LOL
