Page 1 of 3 1 2 3
Aluminum wedge block #2347271
08/02/17 01:48 PM
08/02/17 01:48 PM
Ky
moparmafia Offline OP
Ky
Where can i find a used indy aluminum wedge big block? Really cant afford new right now so my only option would be used.
Re: Aluminum wedge block [Re: moparmafia] #2347501
08/02/17 10:05 PM
08/02/17 10:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Just check around. Here, Yellow Bullet, ForAbodiesonly, forBbodiesonly, forEbodiesonly, Facebook. I got mine off of Racing Junk. Cheap, but needs sleeves. I can deal with that.
[image][/image]
Re: Aluminum wedge block [Re: moparmafia] #2347553
08/02/17 11:03 PM
08/02/17 11:03 PM
Superfreak
Superfreak
Good luck with that.
Re: Aluminum wedge block [Re: ] #2347556
08/02/17 11:07 PM
08/02/17 11:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They are around but guys want them for nothing or hesitate and if the price is right they go fast.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aluminum wedge block [Re: pittsburghracer] #2347568
08/02/17 11:16 PM
08/02/17 11:16 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Engine builders that have them want to build them into engine and sell them. Others that have them do not let them go like their stock blocks. We have had to fix what ever was wrong with them and getting another is a real pain somtimes.
Re: Aluminum wedge block [Re: moparmafia] #2347698
08/03/17 03:03 AM
08/03/17 03:03 AM
Cab_Burge Online work
Cab_Burge  Online Work
Why do you want aluminum?
Re: Aluminum wedge block [Re: Cab_Burge] #2347730
08/03/17 07:49 AM
08/03/17 07:49 AM
Dragula Offline
Dragula  Offline
Why wouldn't you want aluminum? If I could afford it, all my engines would be aluminum.
Re: Aluminum wedge block [Re: moparmafia] #2347867
08/03/17 02:01 PM
08/03/17 02:01 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
I have an iron World wedge block that needs all 8 sleeved.
Prob going to sell it, just havent listed it yet.
Has 4.600 bore. Thats why it needs sleeved.
#8 has hair line crack.
So i figure all 8 need sleeved.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Aluminum wedge block [Re: Dragula] #2347870
08/03/17 02:06 PM
08/03/17 02:06 PM
Ky
Ky
I want the weight loss and the ability to repair. I am going to run a f2 procharger and i would rather not use the old iron blocks.
Re: Aluminum wedge block [Re: Dragula] #2347999
08/03/17 05:12 PM
08/03/17 05:12 PM
All the guys I know who run heads up, N/A or power adders, that have raced with cast grey iron and or with Compact Graphite Iron blocks and with good race aluminum blocks with the same parts in them ran faster at the track and made more power (30 to 80Hp depending on the race,r motor size and RPM and who was telling the story) on the engine dynos they tested on work
What type of blocks do all the Pro Stock team use scope
I'll give you a clue, they ain't aluminum the last time I checked shruggy work
Re: Aluminum wedge block [Re: moparmafia] #2348001
08/03/17 05:14 PM
08/03/17 05:14 PM
I'm glad you did your research on this before making your decision bow up
Good luck on finding a used block luck
I talked to Tim Banning at FHO last week about a new KB low deck aluminum street wedge block (no wet sleeves) for one of my local customers, he said they will make them soon but they ain't cheap whistling shruggy
I assembled a KB street hemi dry sleeve block(#55, I think) for a blower on the street for a customer years ago when Mopar sold them through their dealer network, it work good once we got the EFI problems sorted and tune up correctly work
Re: Aluminum wedge block [Re: moparmafia] #2348012
08/03/17 05:33 PM
08/03/17 05:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well a few observations. I basically prefer aluminum all the time these days, reparability is a part of it but for me weight is the main reason. I think we make a bit of power but I no way believe that the loss of power, if any is made up but the weight savings. Give me the 165-175lbs less weight any day.
The heads up car is also an ALUMINUM block and being a SB Chebbie the choices are endless. The aluminum block was chosen for the same reason. Weight savings.
As for Mopar blocks, they are out there to be certain. When you see one you need to be ready to act. Another thing is on some(indy)if they need sleeves it can get expensive to purchase and have them installed. Not a lot of places will do sleeves in those blocks. Also beware of a block with zero history. At a point aluminum gets "soft" through heat cycles. No different than aluminum rods. I have purchased a few over the years and been bitten once by "soft" material.
Re: Aluminum wedge block [Re: moparmafia] #2348204
08/03/17 11:26 PM
08/03/17 11:26 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm aluminum all the way. I have a steel engine and an aluminum engine. They both have the same heads and the steel one makes 100 more HP than the aluminum engine. It takes a lot more HP to make up for the extra weight. The aluminum engine is faster with less porting, less camshaft, less compression, less flow, etc.
Re: Aluminum wedge block [Re: moparmafia] #2348418
08/04/17 01:40 PM
08/04/17 01:40 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
All things equal the aluminum wins hands down. I did ready some where that ring seal was an issue with aluminum but like stated above the weight saving far outweighs the power lose if there is any.
Re: Aluminum wedge block [Re: moparmafia] #2348541
08/04/17 05:08 PM
08/04/17 05:08 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Ring seal perhaps was a problem on the aluminum blocks of old, but not so much anymore. I know people that run 4.560 sleeves in Mopar aluminum blocks.
Re: Aluminum wedge block [Re: Cab_Burge] #2348661
08/04/17 09:13 PM
08/04/17 09:13 PM
organ
maximum entropy Offline
organ
they use iron because it's in the rule book.
Re: Aluminum wedge block [Re: maximum entropy] #2348769
08/05/17 01:14 AM
08/05/17 01:14 AM
Carl, NHRA tech and the Pro stock team owners and drivers have a rule changing meeting at the end of each year to decide what and how they will change the rules for the next year.
They could have had aluminum blocks years ago but most of the teams like Compact Graphite Iron blocks better shruggy
I wonder what type of blocks NASCAR cup teams use work
Re: Aluminum wedge block [Re: moparmafia] #2348920
08/05/17 12:49 PM
08/05/17 12:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Last I checked not many here are chasing ever last little HP..Trust me aluminum is the way to go unless you are one of those Comp, Pro Stock or Nascar guys on here...
Re: Aluminum wedge block [Re: moparmafia] #2349081
08/05/17 05:38 PM
08/05/17 05:38 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I want to boost the bajeezers out of one! lol
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Aluminum wedge block [Re: moparmafia] #2349095
08/05/17 06:15 PM
08/05/17 06:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Current LSX development suggests that aluminum moves around more than you want at really high power, and that the smallest bore size thickest wall) doesn't hurt much at high boost.
Boffin Emeritus
Page 1 of 3 1 2 3
