8 3/4 axle seal leak #2347254
08/02/17 01:16 PM
08/02/17 01:16 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Rear end has Strange race axles that developed a leak at the axle retainer plate a while back. Bought the car like this so I never assembled it originally and have never tried to fix before.
Stripped it down and found the retainer plate quite deformed so I flattened it out, put a new o-ring and gasket (paper) in it but it still leaks.
Can't find much info about this area from the manual (or in the tech articles) so I'm hoping for some advice on re-assembly to ensure the bearing has the correct clearance and it doesn't leak.
Thanks in advance
Re: 8 3/4 axle seal leak [Re: Mofopar] #2347265
08/02/17 01:36 PM
08/02/17 01:36 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I am assuming you have the "Green Bearings" on the axle because you said you changed the o-ring. If you are not running inner axle seals put them in there. Green bearings are self lubricated and do not need gear oil to lube them. The gear oil is either leaking through the bearing or around the outer edge. The inner axle seal will prevent that.
Jeff
Re: 8 3/4 axle seal leak [Re: Cuda340] #2347273
08/02/17 01:50 PM
08/02/17 01:50 PM
install a new seal, the wide one that you drive in
Re: 8 3/4 axle seal leak [Re: RapidRobert] #2347296
08/02/17 02:20 PM
08/02/17 02:20 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Jeff
Ya, green bearings with O-rings.
Thanks, I'll try the inner seal.
Do you mean the inner oil seal like Jeff above mentions? This gets "driven" into the axle housing, correct?
Re: 8 3/4 axle seal leak [Re: Mofopar] #2347350
08/02/17 03:22 PM
08/02/17 03:22 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
That is correct. It gets driven in.
Re: 8 3/4 axle seal leak [Re: Cuda340] #2347377
08/02/17 04:22 PM
08/02/17 04:22 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I don't recall this seal being there when I replaced the gasket/o-ring.
Reading another thread on this topic; a member mentions interference (mosers) with the seals; I'm hoping this isn't my situation,,,
8 3/4 a body green bearings
Re: 8 3/4 axle seal leak [Re: Mofopar] #2347400
08/02/17 05:07 PM
08/02/17 05:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You should pay attention to Dr Diff's response to that.
Don't be the exception.
