Re: E-Body Front Door Panel Window Seal
[Re: Morty426]
#2345151
07/29/17 09:24 AM
07/29/17 09:24 AM
Posts: 5,024 new berlin wisconsin
Mr T2U
Rob,
Never had this happen. Is the door glass adjusted right?
Chris my thoughts also. i would check the height stop. sounds like the window rolls to far down.
perception is 90% of reality
[Re: B5Cuda440-6]
#2345597
07/30/17 08:46 AM
07/30/17 08:46 AM
Posts: 1,060 Dallas, Texas
FC7cuda
Dallas, Texas
The felt can get worn too, adjustment may be original/correct just need new felt. How does it look?
68 Charger 70 Cuda
[Re: B5Cuda440-6]
#2346021
07/30/17 11:45 PM
07/30/17 11:45 PM
Posts: 1,567 Ky
jt4406
Ky
I ran into this very same issue. I bought the TopCat brand window fuzzies because everyone said they were the best, and all of them worked ok, except the front inner door panel seals. Mine came off when the window was rolled up and down. No one on the board had a solution that worked ( https://board.moparts.org/ubbthreads/ubbt...tml#Post1669624). I wound up finding a couple of good original seals off some old door panels I had, used them, no more problems. If "TopCat" is the "best available", then none are much. My .02 jess
Yeah, it's hopped up to over 160...
