Solid motor mounts for the street? #2345177
07/29/17 11:49 AM
07/29/17 11:49 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Did a few searches and came up dry. Thought there'd be lots ov thread on this?
Anyways, my Challenger project still needs mounts. I found a nice set ov Moroso(?) solid mounts, in nice shape for an absurd price. The car will have a poly trans mount (or could go rubber if its better).
Good? bad? for the street? Daily driver (360 Magnum and 4-speed into 74 Challenger). I dont mind a little NVH, and this engine should be pretty damn smooth.
Issues i might run into?
These are about a third ov the price ov what i'm finding used stuff for, and well... solid IS better for performance, yes?
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345182
07/29/17 11:54 AM
07/29/17 11:54 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Started running solids many years ago then went Elephant ears w/the BB.........Zero issues or concerns........ thumbs
Re: Solid motor mounts for the street? [Re: Thumperdart] #2345184
07/29/17 11:57 AM
07/29/17 11:57 AM
moparx Offline
moparx  Offline
solid mounts are not for everyone, but i like them. remember to use a rubber or poly trans mount.
beer
Re: Solid motor mounts for the street? [Re: moparx] #2345188
07/29/17 12:04 PM
07/29/17 12:04 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
No problems on a 70 RR with 452 and 4 speed. Been running them for years and prefer them over the rubber ones. The carb bowls still hit the side of the cutout in the bonnet when you stand on it. That is most likely chassis flex.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345230
07/29/17 01:10 PM
07/29/17 01:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
All i ever had with my small block. No issues here. I think they set the engine lower as well, so if you have hood clearance issues you might gain some space there.
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345255
07/29/17 01:36 PM
07/29/17 01:36 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Used them for years. Going motor plate on the new engine.
Re: Solid motor mounts for the street? [Re: gsmopar] #2345271
07/29/17 01:58 PM
07/29/17 01:58 PM
fullmetaljacket Offline
Front motor plate, mid way limiters and poly trans mount. No issues.
A little vibration reminds you of what the purpose of such a car is. 4 speeds would be hard on stock rubber mounts anyway so go have fun with the solids.
Re: Solid motor mounts for the street? [Re: fullmetaljacket] #2345275
07/29/17 02:11 PM
07/29/17 02:11 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I run them with no problems. I do prefer a rubber mount on the right side though. These days I don't think I would chance a rubber mount on the left side no matter what, the quality of new rubber mounts is questionable.
Sheldon
Re: Solid motor mounts for the street? [Re: RUNCHARGER] #2345285
07/29/17 02:39 PM
07/29/17 02:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Too "buzzy" on the street for my tastes. I even tried just one on the driver's side... still felt more engine vibration through the car than I wanted. Best combination for me is rubber mounts and a torque strap: no "buzz" and no torn engine mounts.
EDIT: I do use what I believe are called Mighty Mounts, along with a poly trans mount.
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345404
07/29/17 07:41 PM
07/29/17 07:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a solid mount just on the drivers side and a normal rubber mount on the pass side on my street car. Has been like that since 2006. Ron
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345567
07/30/17 05:06 AM
07/30/17 05:06 AM
Swears too much
Swears too much
Good to hear! I can put up with more than most, and i like a more racecar feel. And if they set the plant lower, well thats just icing on the cake. I'm sold.
So, rubber or poly trans mount then? I have both handy.
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2345608
07/30/17 10:13 AM
07/30/17 10:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Depends on your engine really. My 360 wasn't balanced and it would really zing the car sometimes lol. Rubber mounts with a schumacher torque strap solved that. I had to replace and shim the passenger side rubber mount a few times due to it sagging and letting the headers rub the steering. My current 416 is nicely balanced with solid mounts and it is smooth as glass.
68 Barracuda Formula S 340
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2346112
07/31/17 10:30 AM
07/31/17 10:30 AM
an8sec70cuda Offline
Solid mounts or a motorplate is the only way to go IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Solid motor mounts for the street? [Re: Pale_Roader] #2346118
07/31/17 10:53 AM
07/31/17 10:53 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Poly trans mount and full engine plate with poly a bushing on each side - works great wink
