B Body Carpet Fitment Question #2343910
07/26/17 09:24 PM
07/26/17 09:24 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Please describe how the carpeting on a 70 B Body runs from the point it leaves the rear of the sill scuff plates to the point it is hidden under the rear seat bottom.
Does it ride under the windlace?
Does it ride under the quarter interior panel?
Bonus points for a photo.
~Lindy~
I’m listening.
Re: B Body Carpet Fitment Question [Re: Big Bad Bee] #2344043
07/27/17 01:40 AM
07/27/17 01:40 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Not exactly original..but it's a 70 Charger. I would guess the door panel is not original.
Re: B Body Carpet Fitment Question [Re: Big Bad Bee] #2344203
07/27/17 11:48 AM
07/27/17 11:48 AM
Indiana
68_661charger Offline
Indiana
Again a Charger pic here not sure if Coronets use this same trim. I believe there is one screw hole in the trim just under the rear seat and the part under the sill has an open end.
Re: B Body Carpet Fitment Question [Re: Big Bad Bee] #2344468
07/27/17 07:59 PM
07/27/17 07:59 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
There should be a sill plate extension between the sill plate and the rear seat. In the pic below, I am not sure if it is installed correctly or not. The plates are LH and RH specific but are an L shape, so can be installed with the long or short part of the L down depending which side of the car it is.
The extensions are reproduced if you do not have them.
If anyone knows which way is correct/original, please chime in. I have tried them both ways on my car and neither one looks right to me. shruggy
I see in the pic above it is installed the same as my pic, so perhaps that is correct.
Re: B Body Carpet Fitment Question [Re: Big Bad Bee] #2344504
07/27/17 09:43 PM
07/27/17 09:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
mine look opposite of the one above
Re: B Body Carpet Fitment Question [Re: Big Bad Bee] #2344507
07/27/17 09:47 PM
07/27/17 09:47 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
a
Re: B Body Carpet Fitment Question [Re: CSK] #2344613
07/28/17 12:34 AM
07/28/17 12:34 AM
Spokane Valley, WA
Spokane Valley, WA
Hey, all three of you guys, THANK YOU for the photos! I do have the extensions. Completely forgot about them. Easy peazy!
I’m listening.
