R5 Crank adapter fab question #233788
02/23/09 11:46 AM
02/23/09 11:46 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I am getting ready to make my R5 crank adapter.
My question is does it need to be 4340 steel? OR can it be 1045 steel? It will be .375 thick.
This engine will be around 850 hp 560 tq. Just want to make sure this will be strong enough.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Crank adapter fab question [Re: DemonDust] #233789
02/23/09 07:28 PM
02/23/09 07:28 PM
Menomonee Falls
Menomonee Falls
SDG Motorsports
Re: Crank adapter fab question [Re: DemonDust] #233790
02/23/09 09:33 PM
02/23/09 09:33 PM
Minn
SportF Offline
SportF  Offline
Minn
This is a true engineering question. I am to guess that bolts will thread into this adapter from one side, and bolts from the flywheel or flex plate will thread into it from the other side? If this is just a "spacer" and the bolts go all the way thru then any mild steel would even do. But assuming as stated above I will also assume 6 bolts will go each way, 7/16 bolts, grade 8 from each side. Even with this scenario, the 1045 will be good providing there is at least a minimum of , say. 0.250 between the holes from one side to the other. Now if there is like 8 bolts then that separation difference can be far less and once again even mild steel would probably be acceptable. Also, unless you can power tap this with some serious machine, and machining knowledge out of a professional manufacturer with experience with this steel, you probably can't do it. Hand taping those holes in the 4340 is going to be very difficult (if you can do it without breakage). Once again even the 1045 ain't going to be fun. So, from me, I would go with the 1045, but I don't have all your info. Also, if this is for an automatic, you have far less shock loads that with a stick, and that should factor in as well.
Re: Crank adapter fab question [Re: SportF] #233791
02/23/09 10:23 PM
02/23/09 10:23 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If you have the choice between the two then by all mean's go 4340 as it is a much higher quality steel and will machine just as easy and will give a higher quality finish, plus it's tougher and your thread's will hold up better.
Re: Crank adapter fab question [Re: dartman366] #233792
02/24/09 08:10 AM
02/24/09 08:10 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i agree if you have the option go with 4340. although the 1045 should work as well.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Crank adapter fab question [Re: Jerry] #233793
02/24/09 10:09 AM
02/24/09 10:09 AM
Menomonee Falls
Menomonee Falls
It is just a spacer. No threads in it at all. There will be 6 holes in it for the R5 crank. The 6 holes are almost evenly spaced. We will be using grade 8 bolts and the adpater will be .375 thick. From what I read above the 1045 will be more than good?
SDG Motorsports
Re: Crank adapter fab question [Re: DemonDust] #233794
02/24/09 11:55 AM
02/24/09 11:55 AM
AndyF Offline
AndyF  Offline
It is just a spacer? I don't know what the part is doing but it sounds like maybe it is changing the crank flange diameter for the torque converter or something? If it is just a spacer then aluminum would probably work just fine.
Re: Crank adapter fab question [Re: AndyF] #233795
02/24/09 06:10 PM
02/24/09 06:10 PM
Menomonee Falls
Menomonee Falls
It's just a spacer to make up the difference for the adapter plate to go from R5 bellhousing to LA bellhousing. The flywheel is being redrilled for the crank bolt pattern.
SDG Motorsports
Re: Crank adapter fab question [Re: AndyF] #233796
02/26/09 05:38 PM
02/26/09 05:38 PM
Menomonee Falls
Menomonee Falls
So aluminum can be used? This is just a spacer. No threads will be in this piece. It is being used to make up the difference from the crank to flywheel because of the mid plate. We are drilling the flywheel to match the bolt pattern on the crank.
I have a 2024 billet available.
SDG Motorsports
Re: Crank adapter fab question [Re: DemonDust] #233797
02/26/09 05:49 PM
02/26/09 05:49 PM
AndyF Offline
AndyF  Offline
Maybe, depends on how thick it is. I'd have to see the design before I knew which material would work. The bolts are going to transmit the torque, not the spacer so aluminum should be fine. Only problem is if the spacer is fairly thick since then the flywheel could start to whip around. If the spacer is less than 1/2 inch thick then I think aluminum would be fine.
Re: Crank adapter fab question [Re: AndyF] #233798
02/26/09 07:43 PM
02/26/09 07:43 PM
Menomonee Falls
Menomonee Falls
I haven't received the Mid plate yet to measure thickness. But it should be right around .375" We are turning this piece on a lathe, so there shouldn't be any reason for it to be off centered and cause harmonic problems.
Thanks for your input. My engine machinst is worried about the aluminum. Strength wise and the difference in expansion rates? Will this be an issue?
SDG Motorsports
Re: Crank adapter fab question [Re: DemonDust] #233799
02/26/09 09:45 PM
02/26/09 09:45 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
Hey, if you let me know what you want I will cut it for you, just give us a call in the AM.
Rick
Re: Crank adapter fab question [Re: Domino1609] #233800
02/26/09 09:56 PM
02/26/09 09:56 PM
Menomonee Falls
Menomonee Falls
Ok. What number?
SDG Motorsports
Re: Crank adapter fab question [Re: DemonDust] #233801
02/26/09 10:19 PM
02/26/09 10:19 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
The shop,
570-561-1746
Rick
