Re: Bought my first 400 Block this Weekend
[Re: fast68plymouth]
#2346573
08/01/17 09:09 AM
08/01/17 09:09 AM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
These heads, lifters, rockers, and cam were all used on my 440 a few weeks ago and ran 9.70 at 138.50.....pushrods are new for the low deck. All this stuff already works....trying to figure out what didn't work right is frustrating at the moment.
[Re: AndyF]
#2346636
08/01/17 12:37 PM
08/01/17 12:37 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm guessing that the pushrods bent first, they look like flexy flyers. Once they bent then the lifter just got beat to heck until it broke. That's the most likely scenario.
#2346914
08/01/17 09:24 PM
08/01/17 09:24 PM
Dragula
I'm guessing that the pushrods bent first, they look like flexy flyers. Once they bent then the lifter just got beat to heck until it broke. That's the most likely scenario. I am in agreement with that until I learn more I guess.
#2374168
09/20/17 10:16 PM
09/20/17 10:16 PM
Dragula
Well this update took me a while...But a long story short, it was only the damage in the pictures above. A couple of push rods and a lifter.
All the bearings, oil pump, and oil passages in the block were good and clear with nothing in them. Filter caught all of it from the looks of everything. Double checked a bunch of stuff, and nothing else hurt.
So, the lifters I had were old enough that they warranted replacing, and now the engine is back in the car and running...In hind sight, we should have probably changed the valve springs as well, but I have to leave somthing to do this winter, or I will be bored.
Next outing...This Friday/Saturday.....
So to recap this build....440Source 512 kit with light weight crank option, 10.8:1 compression....680 lift cam and Indy EZ1 heads, unported.
[Re: Dragula]
#2374226
09/20/17 11:47 PM
09/20/17 11:47 PM
Thumperdart
State of confusion
So to recap this build....440Source 512 kit with light weight crank option, 10.8:1 compression....680 lift cam and Indy EZ1 heads, unported. It's all a learning curve both good and bad so enjoy the ride and good luck............
[Re: mshred]
#2374356
09/21/17 07:47 AM
09/21/17 07:47 AM
Dragula
Awesome! How much more is the lightweight crank option from 440 source? I think it was $300 and the crank was 6lbs lighter....I like it. Revs very quickly. After driving a 440 of the same cubes, same heads, same compression for 7 years....its noticeable when you touch the gas pedal. I have another 400 block now that I scored for $300 and I also intend to build a 383/496 stroker with a procharger if my Hemi sells. All of them will get the light weight 4.25 crank.
[Re: Cab_Burge]
#2374771
09/21/17 10:44 PM
09/21/17 10:44 PM
Dragula
Well, those darn things just keep me at a disadvantage it seems....Every time I think I have it, another set back.....Even my engine builder sent me a text today about how my Hemi sucks. Thats twice in two weeks in reassembling it that we have encountered issues with it.... On the other hand, the Wedge combo we have come up with has proven fast and fairly low maintenance and lower cost.....Only problem is, the Cuda has Hemi badges on it....But the spare 440/512 short block would really make it run nice......With the right heads and cam.
[Re: Dragula]
#2374916
09/22/17 10:30 AM
09/22/17 10:30 AM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
With all the problems you've had w/ that hemi, I think it's time for another engine builder.
[Re: an8sec70cuda]
#2376016
09/24/17 06:48 PM
09/24/17 06:48 PM
Dragula
With all the problems you've had w/ that hemi, I think it's time for another engine builder. Well, one, the pan that did fit is in pieces. Big stroke, means you need big clearances. Not easy finding stuff that clears 4.75 in a Mopar. Two, the oil pressure issue, I think, is block related. We have a hell of a time with oil pressure and since day 1, somthing has not been right. I think we need some BGR help though. Left AJ a message. Might even take it down there and see what is up with one of the passages in it... On a side not, the 400/512 testing results were about the same. Still has a miss in the upper rpm we have now concluded is a bent valve...Still netted a couple of 6.30's with a 1.39 60ft shifting at 5k.... Heads will be coming off this week...I want to do a leak test and see if it shows up somewhere...
[Re: Ohio Joe]
#2377559
09/27/17 08:24 AM
09/27/17 08:24 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
This was my second low deck to come apart. Got one more left then it will be on to the aftermarket. WOW Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Ohio Joe]
#2377570
09/27/17 09:11 AM
09/27/17 09:11 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
This was my second low deck to come apart. Got one more left then it will be on to the aftermarket. You should be glad you were using a factory block in this situation. Why kill an aftermarket block? I see nothing in that picture saying block failure. Some part of the rotating assembly took that thing out, as it would have with any block.
[Re: TRENDZ]
#2377671
09/27/17 12:43 PM
09/27/17 12:43 PM
Thumperdart
State of confusion
This was my second low deck to come apart. Got one more left then it will be on to the aftermarket. You should be glad you were using a factory block in this situation. Why kill an aftermarket block? I see nothing in that picture saying block failure. Some part of the rotating assembly took that thing out, as it would have with any block. Yep totally agree after looking at that pic for a while cos my junk is going on 16 years w/my dumb azz behind the wheel and still going strong along w/the 413 factory crank.............
[Re: Dragula]
#2377715
09/27/17 02:15 PM
09/27/17 02:15 PM
fast68plymouth
So. Burlington, Vt.
I see nothing in that picture saying block failure. Some part of the rotating assembly took that thing out, as it would have with any block. From the looks of whats visable on the undamaged side of the block, I see no evidence of anything from the rotating assy flailing around.
#2377718
09/27/17 02:21 PM
09/27/17 02:21 PM
Thumperdart
State of confusion
Detination is a killer weather n/a, boost or NOS...............
