Re: 1970 Cuda Parking Brake Cables
[Re: Mastershake340]
#2337371
07/15/17 02:43 PM
07/15/17 02:43 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Really? Are the parking brake cables different between a '70 cuda and '70 Challenger? The drivers side cable is less than 2' long and the passenger side is close to 4' long on my 70 Challengers. I'd check the restoration vendors for parking brake cables, parts stores apparently don't have what you need, and their black plastic coated ones look nothing like OE anyway. 70-1 Challenger have the long/short cable set up mounted on the driver's frame rail in tandem, IIRC in 72 the Challenger adopted the Cuda cable set up Some 70 Cudas have the long/short cable set up like the Challenger ,as to why?...but most are the dual equal length cables with the equalizer cable/rod Cuda set up below 70/71
[Re: DAYCLONA]
#2337393
07/15/17 03:21 PM
07/15/17 03:21 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Interesting, learn something new everyday. I thought engineering at my heavy duty truck manufacturer employer was an inefficient mess, where the right hand doesn't often doesn't know, or pay attention, to what the left hand is doing. And thus leading to overly complicated, prolific numbers of configurations and numbers of part numbers, but I see things now aren't any different than they were half a century ago at Chrysler!
[Re: jim6346]
#2337433
07/15/17 04:35 PM
07/15/17 04:35 PM
Posts: 608 TN
1DGEMAN
TN
Our early build Cuda has the long/short cables. What brackets are under your car? That tells you what cables you need
Real Men shift for themselves
[Re: jim6346]
#2337614
07/15/17 11:44 PM
07/15/17 11:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
And, it figures. Mine has the tandem cables like the one above with the gray floor...
Nothing on this car has been easy lol.
Thanks Dayclona for the pictures, they were a HUGE help!!
Anyone know where I can get the right cables?
Thanks, Jim Inline Tube...
[Re: Alaskan_TA]
#2339304
07/18/17 08:03 PM
07/18/17 08:03 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The setup with the equalizer was NEW for the 1971 model year. If you see a '1970' E-body with the newer setup, run away. Some loser probably swapped the numbers to a newer body. Agree. I have three 70 E's here now and all have the earlier setup with different length cables and thats all I've seen on a 70.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
