1970 Cuda Parking Brake Cables #2337338
07/15/17 01:44 PM
07/15/17 01:44 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi Everyone,
I went to NAPA to get a set of the rear parking brake cables for my 70 Cuda. The only list the front and the left rear. Tried Autozone and Advanced Auto, same thing. None of them knew why there was no right side listed.
My question is, are the left and the right cables the same? If not, anyone have a partnumber for the right side?
Thanks!!
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2337347
07/15/17 02:14 PM
07/15/17 02:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
L and R are the same on the 70 Cuda
There are some applications late build 70 IIRC where the passenger cable travels over to the drivers side requiring the longer pass cable, and both are mounted in tandem on the driver's frame rail... make sure you have frame provisions on the passenger frame for the short cable, and you have the equalizer cable and rod
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2337352
07/15/17 02:19 PM
07/15/17 02:19 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks!!
Re: 1970 Cuda Parking Brake Cables [Re: DAYCLONA] #2337356
07/15/17 02:21 PM
07/15/17 02:21 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Really? Are the parking brake cables different between a '70 cuda and '70 Challenger?
The drivers side cable is less than 2' long and the passenger side is close to 4' long on my 70 Challengers.
I'd check the restoration vendors for parking brake cables, parts stores apparently don't have what you need, and their black plastic coated ones look nothing like OE anyway.
Re: 1970 Cuda Parking Brake Cables [Re: Mastershake340] #2337371
07/15/17 02:43 PM
07/15/17 02:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70-1 Challenger have the long/short cable set up mounted on the driver's frame rail in tandem, IIRC in 72 the Challenger adopted the Cuda cable set up
Some 70 Cudas have the long/short cable set up like the Challenger ,as to why?...but most are the dual equal length cables with the equalizer cable/rod
Cuda set up below 70/71
Re: 1970 Cuda Parking Brake Cables [Re: DAYCLONA] #2337375
07/15/17 02:47 PM
07/15/17 02:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a 70 Cuda with the tandem mount cables
Re: 1970 Cuda Parking Brake Cables [Re: DAYCLONA] #2337378
07/15/17 02:51 PM
07/15/17 02:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a 70 with symmetrical length cables, pretty much the norm 70-4
Re: 1970 Cuda Parking Brake Cables [Re: DAYCLONA] #2337393
07/15/17 03:21 PM
07/15/17 03:21 PM
Crook County, ILL
Crook County, ILL
Interesting, learn something new everyday.
I thought engineering at my heavy duty truck manufacturer employer was an inefficient mess, where the right hand doesn't often doesn't know, or pay attention, to what the left hand is doing. And thus leading to overly complicated, prolific numbers of configurations and numbers of part numbers, but I see things now aren't any different than they were half a century ago at Chrysler! shruggy
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2337433
07/15/17 04:35 PM
07/15/17 04:35 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Our early build Cuda has the long/short cables. What brackets are under your car? That tells you what cables you need
Real Men shift for themselves
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2337450
07/15/17 05:10 PM
07/15/17 05:10 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
And, it figures. Mine has the tandem cables like the one above with the gray floor...
Nothing on this car has been easy lol.
Thanks Dayclona for the pictures, they were a HUGE help!!
Anyone know where I can get the right cables?
Thanks,
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2337614
07/15/17 11:44 PM
07/15/17 11:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks,
Inline Tube...
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2338066
07/16/17 10:54 PM
07/16/17 10:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The setup with the equalizer was NEW for the 1971 model year.
If you see a '1970' E-body with the newer setup, run away. Some loser probably swapped the numbers to a newer body. twocents
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2338272
07/17/17 11:36 AM
07/17/17 11:36 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Mine definitely has the tandem.. Cables on order. Thanks again everyone!!
Re: 1970 Cuda Parking Brake Cables [Re: jim6346] #2339285
07/18/17 07:22 PM
07/18/17 07:22 PM
St. Louis
I
Imrare Offline
Imrare  Offline
I
St. Louis
I bought my set from Inline Tube. They have an ebay store, search under 1970 Cuda Emergency Brake Cable. Tired to attach a link.
http://www.ebay.com/itm/70-71-E-body-Cuda-W-inner-E-Emergency-Parking-Brake-Cable-Set-Kit-OE-BSH7001-/200914282690?fits=Year%3A1970%7CModel%3ACuda&hash=item2ec76ca8c2:g:X-8AAOSwvgdW2ytK&vxp=mtr
Re: 1970 Cuda Parking Brake Cables [Re: Alaskan_TA] #2339304
07/18/17 08:03 PM
07/18/17 08:03 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Agree. I have three 70 E's here now and all have the earlier setup with different length cables and thats all I've seen on a 70.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
