67 gtx steering column ...need help
#2337306
07/15/17 12:13 PM
07/15/17 12:13 PM
Posts: 155 Utah, USA
tweeter1
Utah, USA
Need your help, 19676 GTX changed from a column shift automatic, duh!, to a floor shift. My problem is... When I purchased the floor shift column it didn't come with the mounting bracket /clamp, so I used the one from the column shift. after making all the adjustments to the steering box I bolted the column up under the dash and noticed the plate that bolts to the firewall was high enough I couldn't start the bolts, I went up top an noticed the column was touching the chrome ring. At this point I dropped the column approx. a half inch and the floor plate, although not perfectly aligned was now close enough, Obviously I could use spacers where the column mounts to the body, However I was curious if Mopar used a different clamp/bracket for floor shift columns? I can't imagine, but at this point I am at a loss.
Thanks Bob
Re: 67 gtx steering column ...need help
[Re: tweeter1]
#2337316
07/15/17 12:52 PM
07/15/17 12:52 PM
Posts: 5,163 CT
GTX MATT
CT
No that bracket is the same. You didn't somehow try to install with the firewall mounting plate 180 degrees off did you? (upside down) If you can post some pictures of your mounting points as installed and maybe we can see whats going on. ALSO, what do you mean by adjustments to the steering box? You shouldn't have had to do anything to that.
[Re: GTX MATT]
#2337362
07/15/17 02:29 PM
07/15/17 02:29 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
If you can post some pictures of your mounting points as installed and maybe we can see whats going on. ALSO, what do you mean by adjustments to the steering box? You shouldn't have had to do anything to that. Fully agree
[Re: tweeter1]
#2337582
07/15/17 09:54 PM
07/15/17 09:54 PM
Posts: 5,163 CT
GTX MATT
CT
Email me your pics if you can, pistolgrip440-6@sbcglobal.net
[Re: tweeter1]
#2337904
07/16/17 06:53 PM
07/16/17 06:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Are you using the column shifted parts to add the floor shift column? I wonder if the floor shifted column might not have a different bracket.
I have mechanical Aptitude. I can screw up anything.
[Re: tweeter1]
#2337925
07/16/17 07:22 PM
07/16/17 07:22 PM
bboogieart
Lost and Spaced
It was just a thought. I'm sure you'll get it sussed out.
[Re: tweeter1]
#2352490
08/11/17 05:43 PM
08/11/17 05:43 PM
Posts: 5,163 CT
GTX MATT
CT
Hey, just had a thought on this. I think I know your problem.
The column bracket has 3 bolts, the bolt that is by itself further under the dash bolts to a braket attached to the pedal assembly. This bracket is adjustable where it bolts to the pedal assembly (2 studs), it probably need ti be loosened and adjusted up.
