833 18 spline #'s #2334498
07/10/17 02:23 AM
07/10/17 02:23 AM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
i still don't know how to tell what car this come out of by the #'s.someone might be looking for it.it's PP833 2288 0009 and serial # is 8G177160.also how bad is the price affected by a shortened input shaft?
TIA for any info.
Re: 833 18 spline #'s [Re: kdsmith07] #2334508
07/10/17 02:46 AM
07/10/17 02:46 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It came out of a '68 built in St. Louis. Nov 2, 1967 build (I'm not sure if that's the date the trans was built or if SPD of the car, but I suspect the trans).
The input shaft depends on whether it was just cut short or cut short and turned smaller to fit a GM (was quite common). You can run the cut down shaft with the pilot bearing that fits the crank snout. It will decrease the value some, though.
Re: 833 18 spline #'s [Re: kdsmith07] #2334521
07/10/17 03:14 AM
07/10/17 03:14 AM
Loganville GA.
K
K
Loganville GA.
wouldn't that date of 2288 make it a 69.when i look it up it says nov.of 68.idk.the more i try to learn the more confused i get.lol.the shaft was just cut a little short.thanks jim
Re: 833 18 spline #'s [Re: kdsmith07] #2334527
07/10/17 03:38 AM
07/10/17 03:38 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
11/02/67 = transmission assembly date
12/13/67 = car's "scheduled" production date
if it has always been an 18-spline,
then it was from a HEMI Road Runner OR 440/HEMI GTX
RM21J8G
RS23L8G / RS23J8G
RS27L8G / RS27J8G
Re: 833 18 spline #'s [Re: kdsmith07] #2334660
07/10/17 12:58 PM
07/10/17 12:58 PM
Loganville GA.
K
K
Loganville GA.
ok,got it.thanks dan
Re: 833 18 spline #'s [Re: kdsmith07] #2334766
07/10/17 03:30 PM
07/10/17 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ya gotta remember that production of '68 parts started in mid/late '67 so, in any model year, parts dated after late in a year are for the next year's model.
Re: 833 18 spline #'s [Re: kdsmith07] #2334792
07/10/17 04:10 PM
07/10/17 04:10 PM
Loganville GA.
K
K
Loganville GA.
thanks for that info john.it's appreciated
Re: 833 18 spline #'s [Re: kdsmith07] #2334894
07/10/17 07:47 PM
07/10/17 07:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
2288 is not the 228th day of 1968
it's the 2288th day of the 10000 day calendar
Re: 833 18 spline #'s [Re: kdsmith07] #2334898
07/10/17 07:49 PM
07/10/17 07:49 PM
Loganville GA.
K
K
Loganville GA.
that would explain a lot.thanks morty
Re: 833 18 spline #'s [Re: kdsmith07] #2334901
07/10/17 07:54 PM
07/10/17 07:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No problem. It's that last 8 that threw you. If it had been built a week later 2295 you would have known it was a different kind of calendar.
