Re: Transmission gets stuck in park
[Re: 68dodge]
#2333754
07/08/17 07:04 PM
07/08/17 07:04 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What part are you calling the "park paw"?
[Re: 68dodge]
#2333756
07/08/17 07:11 PM
07/08/17 07:11 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Shifter/linkage/cable flexing, deflecting?
[Re: 68dodge]
#2333800
07/08/17 09:21 PM
07/08/17 09:21 PM
Posts: 516 ,Pa.
68dodge
,Pa.
It is not the linkage. You have to jack the truck up, move the rear wheels forward and reverse by hand. Then you can shift it out of park. Work good on the a flat surface. Once you on a very little grade it stuck again.
[Re: CRT]
#2334028
07/09/17 12:22 PM
07/09/17 12:22 PM
Posts: 516 ,Pa.
68dodge
,Pa.
last week I was closed, we are moving into a new shop. Phones where down for a few days, call me Monday, and until then, park on flat ground. You dont need Park to race. No kidding you do not park to race. How am supposed to get there if it stuck in park. Live up to it, your CRT transmission is junk. Yes I am unhappy after spending $3100 on a CRT transmission.
[Re: 68dodge]
#2334211
07/09/17 05:13 PM
07/09/17 05:13 PM
John_Kunkel
Rio Linda, CA
FWIW, every incidence of getting stuck in Park that I've experienced was due to an incorrect Park rod. The 904 rod works OK in the 727 most of the time except when under load. In the pic below the 904 is at the top.
[Re: Dave Hall]
#2334241
07/09/17 06:02 PM
07/09/17 06:02 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
This would be a very good time for thought out PMs between the players
"Just a Bracket car dressed up like a streetcar"
[Re: John_Kunkel]
#2334447
07/10/17 12:28 AM
07/10/17 12:28 AM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
This had crossed my mind, I am very aware of the difference, but I could of made the mistake. Something that needs to be checked.
[Re: CRT]
#2334953
07/10/17 09:38 PM
07/10/17 09:38 PM
Posts: 516 ,Pa.
68dodge
,Pa.
This had crossed my mind, I am very aware of the difference, but I could of made the mistake. Something that needs to be checked. If you made the mistake, is CRT transmissions going to pay the shipping to sent it back to you to fix the problem?
[Re: J_BODY]
#2335171
07/11/17 07:32 AM
07/11/17 07:32 AM
Posts: 516 ,Pa.
68dodge
,Pa.
are you not capable of removing the valve body? Maybe there's a member around your area that could lend a hand. After spending $3100 on this transmission, I should not have to work on it. It was supposed to new. Plus if something else is not right with this transmission. Am I going to be the blame since I removed the valve body?
[Re: 68dodge]
#2335175
07/11/17 08:43 AM
07/11/17 08:43 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
This had crossed my mind, I am very aware of the difference, but I could of made the mistake. Something that needs to be checked. If you made the mistake, is CRT transmissions going to pay the shipping to sent it back to you to fix the problem? Is your shifter adjusted correctly?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2335474
07/11/17 08:02 PM
07/11/17 08:02 PM
Posts: 2,826 NY usa
540challenger
NY usa
This had crossed my mind, I am very aware of the difference, but I could of made the mistake. Something that needs to be checked. If you made the mistake, is CRT transmissions going to pay the shipping to sent it back to you to fix the problem? Is your shifter adjusted correctly? Better question would be.. is the problem occuring with the linkage on or off the transmission
