Page 1 of 3 1 2 3
Transmission gets stuck in park #2333724
07/08/17 06:07 PM
07/08/17 06:07 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Need help on what to do with 727 trans. It was built by CRT and is new. CRT sent me another park paw. Installed it. Still does not want to come out of park on any slight grade. CRT has not returned my phone call. Would the ball be sticking on the shift lever? Not to happy right now after spending $3100 on this transmission, since I finally got the truck together and can not even race it.
Re: Transmission gets stuck in park [Re: 68dodge] #2333754
07/08/17 07:04 PM
07/08/17 07:04 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
What part are you calling the "park paw"?
Re: Transmission gets stuck in park [Re: 68dodge] #2333756
07/08/17 07:11 PM
07/08/17 07:11 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Shifter/linkage/cable flexing, deflecting?
Re: Transmission gets stuck in park [Re: CMcAllister] #2333762
07/08/17 07:27 PM
07/08/17 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Readjust the park position
wave
Re: Transmission gets stuck in park [Re: 68dodge] #2333785
07/08/17 08:40 PM
07/08/17 08:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well the good book often mentioned about setting the park brake before trans in park to avoid "the bind" of vehicle weight resting on the park pawl.....
if it's happening on flat ground (05-07 trucks come to mind) I've removed the valve body and hit the rooster comb with a dremel to smooth out a ridge that had formed over time from the ball hitting the bottom of the park notch (wear).
Re: Transmission gets stuck in park [Re: 68dodge] #2333800
07/08/17 09:21 PM
07/08/17 09:21 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
It is not the linkage. You have to jack the truck up, move the rear wheels forward and reverse by hand. Then you can shift it out of park. Work good on the a flat surface. Once you on a very little grade it stuck again.
Re: Transmission gets stuck in park [Re: 68dodge] #2333826
07/08/17 09:59 PM
07/08/17 09:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
definitely not rooster comb related.... sure some modification of the park rod will do it up!
to any trans builders credit... no way to check this on the bench. There it will go into park and out all day long. Personally I'd grind some on the ball end of the park rod smoothing the angle more. Since you mentioned "race"... is that race only, or does it see some street time also? It might be a "NEW"...to you trans, but most of those parts involved are just old factory stuff. Could be the lever in the tailshaft housing needing some tweeking too.
Re: Transmission gets stuck in park [Re: 68dodge] #2333931
07/09/17 02:28 AM
07/09/17 02:28 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
last week I was closed, we are moving into a new shop. Phones where down for a few days, call me Monday, and until then, park on flat ground. You dont need Park to race.
shruggy
Re: Transmission gets stuck in park [Re: CRT] #2334028
07/09/17 12:22 PM
07/09/17 12:22 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
shruggy
No kidding you do not park to race. How am supposed to get there if it stuck in park. Live up to it, your CRT transmission is junk. Yes I am unhappy after spending $3100 on a CRT transmission.
Re: Transmission gets stuck in park [Re: 68dodge] #2334184
07/09/17 04:40 PM
07/09/17 04:40 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
CRT is Junk? is this the road you want to go down?
Re: Transmission gets stuck in park [Re: 68dodge] #2334211
07/09/17 05:13 PM
07/09/17 05:13 PM
Rio Linda, CA
Rio Linda, CA
FWIW, every incidence of getting stuck in Park that I've experienced was due to an incorrect Park rod. The 904 rod works OK in the 727 most of the time except when under load. In the pic below the 904 is at the top.
Re: Transmission gets stuck in park [Re: 68dodge] #2334224
07/09/17 05:31 PM
07/09/17 05:31 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Ok. The "you don't race in park" and the "CRT is junk" comments are obviously said in frustration. Let's get to the solution and help the OP out.
Re: Transmission gets stuck in park [Re: Dave Hall] #2334241
07/09/17 06:02 PM
07/09/17 06:02 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
This would be a very good time for thought out PMs between the players
"Just a Bracket car dressed up like a streetcar"
Re: Transmission gets stuck in park [Re: 68dodge] #2334243
07/09/17 06:06 PM
07/09/17 06:06 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
Had and issue with CRT too. Had a front clutch drum I bought and had set up and started to have problems with it shifting into high gear. Took it a art and had .145 clearance in it. Good luck in getting it fixed.
Re: Transmission gets stuck in park [Re: John_Kunkel] #2334447
07/10/17 12:28 AM
07/10/17 12:28 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
This had crossed my mind, I am very aware of the difference, but I could of made the mistake. Something that needs to be checked.
Re: Transmission gets stuck in park [Re: CRT] #2334953
07/10/17 09:38 PM
07/10/17 09:38 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
If you made the mistake, is CRT transmissions going to pay the shipping to sent it back to you to fix the problem?
Re: Transmission gets stuck in park [Re: 68dodge] #2335015
07/10/17 11:05 PM
07/10/17 11:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
are you not capable of removing the valve body? Maybe there's a member around your area that could lend a hand.
Re: Transmission gets stuck in park [Re: J_BODY] #2335171
07/11/17 07:32 AM
07/11/17 07:32 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
After spending $3100 on this transmission, I should not have to work on it. It was supposed to new. Plus if something else is not right with this transmission. Am I going to be the blame since I removed the valve body?
Re: Transmission gets stuck in park [Re: 68dodge] #2335175
07/11/17 08:43 AM
07/11/17 08:43 AM
jersey
Spaceman Spiff Offline
jersey
Is your shifter adjusted correctly?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Transmission gets stuck in park [Re: Spaceman Spiff] #2335474
07/11/17 08:02 PM
07/11/17 08:02 PM
NY usa
540challenger Offline
NY usa
Better question would be.. is the problem occuring with the linkage on or off the transmission
Page 1 of 3 1 2 3
