New Combo Finally Headed to the Track #2332522
07/06/17 02:51 PM
07/06/17 02:51 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Well... it's been 1 1/2 years since my last motor grenaded and unless mother nature throws a wrench in things I'm going to make some tnt passes tomorrow night. Here's the combo. I'll give updates on ET after I make some passes
'68 cuda - 3300 with me
automatic (5000 stall) / 4.88 dana
557 cu in (4.500 bore x 4.375 stroke)
14:1 comp
comp roller - .75/.73 - 286/300 @ .050
Indy EZ-1s (350int / 245exh)
single dominator (flows 1180)
details to follow....
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2332525
07/06/17 02:56 PM
07/06/17 02:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Glad to hear you will be making out again. Should run well I would think. Hopefully we can make it out there tomorrow.
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2332528
07/06/17 03:00 PM
07/06/17 03:00 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good luck! boogie
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2332582
07/06/17 04:18 PM
07/06/17 04:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good luck and keep this puppy together.......... thumbs
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2332684
07/06/17 06:42 PM
07/06/17 06:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Wow that ought to haul the mail, good luck!
Re: New Combo Finally Headed to the Track [Re: ProSport] #2332729
07/06/17 08:37 PM
07/06/17 08:37 PM
an8sec70cuda Offline
iagree Ought to be a fun ride!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New Combo Finally Headed to the Track [Re: an8sec70cuda] #2332946
07/07/17 09:28 AM
07/07/17 09:28 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Good luck Jack. I will be waiting to here from your dad how it went. Ron
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2333442
07/08/17 02:48 AM
07/08/17 02:48 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Why such a steep gear for the combo?
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2333497
07/08/17 10:19 AM
07/08/17 10:19 AM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Well... it was a rough first outing. Had a bunch of electrical issues including a starter that went bad. Also, found out the hard way that either the oil filter wasn't tight enough or some how loosened itself coming out of the water box. That is also when the started decided to quit. So... now it's back to the shop. Need to put a new starter on, make sure things are okay with the motor and sort some battery issues. I need to invest in a good battery that will handle the big cube / big compression. Hopefully back out in two weeks.
Al, thanks for coming out. It was nice meeting you and your wife. Wish you could have seen a little more of a running car.
Viper, the gear in the car is what was with the old combo. I figure I'll need to reduce once I figure this combo out a bit. For now I'm compensating with a 14.5 x 33 good year with lots of rollout.
For what it's worth she was a monster in the water box on it's first burnout.
Re: New Combo Finally Headed to the Track [Re: JACK1440] #2334711
07/10/17 02:25 PM
07/10/17 02:25 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Al, nothing major. The motor is back to running again. The new starter went right on and is working fine. Next to figure out of temp issue. A fellow racers suggested restricting the water flow a bit. Currently we have no thermostat and the theory is the passing thru the radiator too fast. Plan is to go back out Friday the 21st.
Re: New Combo Finally Headed to the Track (Update) [Re: JACK1440] #2359262
08/24/17 06:48 PM
08/24/17 06:48 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Well.. the weather is looking great for tomorrow and back we go to the track to try and make some passes. The fixes / upgrades included new ground wire from the battery to the bell housing, a rebuild starter, a new battery, a new drive shaft (turns out the old one was bent from the last motor destruction), an addition of a water restrictor to slow the coolant down and a new rocker arm (ended up breaking one) found it when we adjusted the valves. Numbers to come.....
Re: New Combo Finally Headed to the Track (Update) [Re: JACK1440] #2359263
08/24/17 06:54 PM
08/24/17 06:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Goodluck and I can't wait to hear the results
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
