Cam Degree Question for my 505 #2333264
07/07/17 07:57 PM
07/07/17 07:57 PM
Middletown , Ohio
DonnieLawson Offline OP
Middletown , Ohio
getting ready to degree the cam, and was wanting your guys expertise for where to degree it at smile
440 stroked to 505, 11.2 compression, ported Stealth heads, victor intake, 950 Holly, MSD.
Comp Cams Solid XTQ294S-8. 68 Cuda, 727 and 3.73 Dana....
Weekend warrior/cruiser and occasional strip use.
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333281
07/07/17 08:23 PM
07/07/17 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd put it in at 104-105
wave
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333288
07/07/17 08:32 PM
07/07/17 08:32 PM
Washington
madscientist Offline
Washington
106 if you have a timing chain.
108 if you have a gear or belt drive.
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333323
07/07/17 10:19 PM
07/07/17 10:19 PM
How good is your chassis and traction? If so so or worse then installed it straight up, if good or better advance to 102, 103 or 104 intake lobe center up
Be ready for neck snapping acceleration with good traction boogie devil
Re: Cam Degree Question for my 505 [Re: Cab_Burge] #2333334
07/07/17 10:52 PM
07/07/17 10:52 PM
Middletown , Ohio
Middletown , Ohio
Car is still not together... run around from Bodyshop hell... thats another story.
But 90/10 shocks up front, Dana with 3.73 gears. Cope racing built 727 and a Dynamic converter, super stock springs on drag radials. subframe connectors and 6 point roll-bar, mini tubbed..
Should be fun
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333448
07/08/17 03:00 AM
07/08/17 03:00 AM
Install that rascal at 102 to 105 ILC and hope it hooks well on those tires thumbs
Be prepared to lift your right foot off the throttle once those tires start to spin, the radials won't recover until they stop spinning shock Can you say Donuts occur shortly after the rear tires start spinning devil shruggy
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333501
07/08/17 10:43 AM
07/08/17 10:43 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Wherever you choose, Chains stretch, and belts measured without load will be retarded in action. Plan for it in set up.
Re: Cam Degree Question for my 505 [Re: MR_P_BODY] #2333578
07/08/17 12:52 PM
07/08/17 12:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
wave
Same here.
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2333839
07/08/17 10:17 PM
07/08/17 10:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
106.5 install center line would give theoretical split overlap Intake opens 25.5 BTDC, Exhaust closes 25.5 ATDC. Add in some chain stretch and 105 to 106 should be good.
Re: Cam Degree Question for my 505 [Re: 451Mopar] #2336635
07/13/17 08:02 PM
07/13/17 08:02 PM
Middletown , Ohio
Middletown , Ohio
I finally got the cam dialed in. as close as I could get it anyway.
I had to advance it 8 deg on the crank., No more adjustment with the timing chain unless i use offset bushings I guess...
I'm using A JP Performance Double Roller Timing Chain 5606T
The #1 intake is now at 106 deg center-line.
intake opening @ .050 is at 26 deg btdc
I was surprised I had to advance it 8 deg... I even triple checked my method...
I verified TDC of the piston with a piston stop and dial indicator,The piston was roughly 1/2" down in he hole for this.
I used the center-line method @ .50 on the cam and also verified lifter opening @.050 using a dial indicator
This isn't my 1st cam install.... but it is the first one I used a degree wheel on smile
The picture is the intake lobe opening @ .050 on the degree wheel
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2336752
07/14/17 01:07 AM
07/14/17 01:07 AM
Are you basing your intake cam timing off of the cam card or are you using the .050 before and after max lift on the intake lobe?
If based on the cam card try using the intake lobe timing at .050 before and again after max lift on the intake lobe and then verify the exhaust lobe is moved the same amount in relation to TDC scope work
I've had more than one custom ground camshaft not have the lobe centers ground correctly on both sides of the cam puke down
I've also had more then one timing set that the dots are not aligned or marked correctly on the cam sprocket shock
If the cam gear dot will not aligned perfectly with the crank gear dot move the cam gear dot one tooth to the passenger side and recheck your results twocents
I HATE MURPHY runaway shruggy
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2336819
07/14/17 09:54 AM
07/14/17 09:54 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just double-check your measuring the Intake lobe and not the exhaust lobe. The first lifter bore is the exhaust because of the valve arrangement on the head.
Re: Cam Degree Question for my 505 [Re: Cab_Burge] #2336824
07/14/17 10:09 AM
07/14/17 10:09 AM
Middletown , Ohio
Middletown , Ohio
I used the measurements off the #1 intake lifter @ .050 before and after max lift to get the center-line.
So... it's advanced 2 deg from what the can card recommended.
I measured and have 106 deg intake center-line after advancing the crank sprocket 8 deg, the cam card calls for 108..
and the intake opening at .050 on the lifter is now at 26 deg, the cam card is 24 deg.. so the math jives between the two measurements... 2 deg.
So the two measurements tell me I advanced the cam 2 deg from what Comp recommends.... right ?
from 108 center-line to 106 center-line
Which what I understand, 104-106 is what the guys on the board would like to see smile
I used the intake , the second lifter from the front on the drivers side smile
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2336843
07/14/17 11:19 AM
07/14/17 11:19 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Not saying it couldnt happen, but I have never had to advance a 108 cam 8 degrees to get it "back" to 106. Please double check all your readings and especially TDC. Its basically saying they had the cam at 114 degrees, which again, sh*t happens, but I find it hard to believe. I have put in a lot of Comps, and have never had that issue. I also vote for a safe and generic 104* install.2* is hardly noticable, but 104 is a great "safe and happy" spot on most 108 cams. Best of luck.
RIP Monte Smith
Re: Cam Degree Question for my 505 [Re: CompWedgeEngines] #2336850
07/14/17 11:31 AM
07/14/17 11:31 AM
Middletown , Ohio
Middletown , Ohio
That's why I posted it... I thought it was pretty far out.
I will go through remeasuring again today...It won't take long with the engine still being on the stand
I did recheck the piston TDC before my last adjustment..
Wish me luck smile
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2336858
07/14/17 11:54 AM
07/14/17 11:54 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
1 tooth on the cam gear is 8* so you may be 1 tooth off there or you can advance it like that as your 106 if this helps any.
Re: Cam Degree Question for my 505 [Re: DonnieLawson] #2336867
07/14/17 12:15 PM
07/14/17 12:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
It is what it is....... You degreed it...... You triple checked it.
You're good to go.
What you found is exactly why they should always be checked.
If you feel like you need to prove it to yourself one more time, degree the exhaust lobe.
It should now be at 110.
Fwiw, I don't really rely on the cam card info to determine if the cam is in correct by the open/close points.
I use the degree wheel to determine the open/close points, then calculate the actual duration @.050, then use that figure to come up with the theoretical c/l of the lobe...... Then move it to where I want it(if necessary).
Ideally, my measured duration @.050 number and the cam card agree with each other, but they don't always....... Especially with rollers.
I guess what I'm saying is, I don't just use one reference point on the cam card(in your case, intake opening) to determine if the cam is where I want it.
Re: Cam Degree Question for my 505 [Re: Clanton] #2336875
07/14/17 12:29 PM
07/14/17 12:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
One tooth is 14deg on the degree wheel.
Re: Cam Degree Question for my 505 [Re: fast68plymouth] #2336889
07/14/17 01:08 PM
07/14/17 01:08 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
14.4 smile
720 crank degrees / 50 cam teeth
Joe
Without Data, you’re just another guy with an opinion.
Re: Cam Degree Question for my 505 [Re: sr4440] #2336903
07/14/17 02:11 PM
07/14/17 02:11 PM
Middletown , Ohio
Middletown , Ohio
Rechecked it all today....
Piston TDC was still correct
But... I was mistaken, the crank gear was set for 6 deg advance, not the 8 i mentioned.... I'm guessing it was brain fade out in the hot barn to recall 8 deg.
It looks like the timing chain marks don't line up correctly... I moved it to either side, but still looks off some... all the other cam numbers looked good
And I got new comp lifters, the old ones... which were still in shrink wrap started to get some rust on the lobe side... look at the difference where the pushrod goes...
Old on the left, new on the right.. what gives with the new solids ?
505 Stroker cam degreeing 8.jpg505 Stroker cam degreeing 7.jpg505 Stroker cam degreeing 3.jpgcomp solid lifters 2.jpg
