Cam Degree Question for my 505
#2333264
07/07/17 07:57 PM
07/07/17 07:57 PM
Posts: 229 Middletown , Ohio
DonnieLawson
Middletown , Ohio
getting ready to degree the cam, and was wanting your guys expertise for where to degree it at ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) 440 stroked to 505, 11.2 compression, ported Stealth heads, victor intake, 950 Holly, MSD. Comp Cams Solid XTQ294S-8. 68 Cuda, 727 and 3.73 Dana.... Weekend warrior/cruiser and occasional strip use.
Re: Cam Degree Question for my 505
[Re: DonnieLawson]
#2333288
07/07/17 08:32 PM
07/07/17 08:32 PM
Posts: 4,457 Washington
madscientist
Washington
106 if you have a timing chain. 108 if you have a gear or belt drive.
[Re: Cab_Burge]
#2333334
07/07/17 10:52 PM
07/07/17 10:52 PM
DonnieLawson
Middletown , Ohio
Car is still not together... run around from Bodyshop hell... thats another story. But 90/10 shocks up front, Dana with 3.73 gears. Cope racing built 727 and a Dynamic converter, super stock springs on drag radials. subframe connectors and 6 point roll-bar, mini tubbed.. Should be fun
[Re: DonnieLawson]
#2333448
07/08/17 03:00 AM
07/08/17 03:00 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Install that rascal at 102 to 105 ILC and hope it hooks well on those tires ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Be prepared to lift your right foot off the throttle once those tires start to spin, the radials won't recover until they stop spinning ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) Can you say Donuts occur shortly after the rear tires start spinning
[Re: 451Mopar]
#2336635
07/13/17 08:02 PM
07/13/17 08:02 PM
DonnieLawson
Middletown , Ohio
I finally got the cam dialed in. as close as I could get it anyway. I had to advance it 8 deg on the crank., No more adjustment with the timing chain unless i use offset bushings I guess... I'm using A JP Performance Double Roller Timing Chain 5606T The #1 intake is now at 106 deg center-line. intake opening @ .050 is at 26 deg btdc I was surprised I had to advance it 8 deg... I even triple checked my method... I verified TDC of the piston with a piston stop and dial indicator,The piston was roughly 1/2" down in he hole for this. I used the center-line method @ .50 on the cam and also verified lifter opening @.050 using a dial indicator This isn't my 1st cam install.... but it is the first one I used a degree wheel on ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) The picture is the intake lobe opening @ .050 on the degree wheel
[Re: Cab_Burge]
#2336824
07/14/17 10:09 AM
07/14/17 10:09 AM
DonnieLawson
Middletown , Ohio
I used the measurements off the #1 intake lifter @ .050 before and after max lift to get the center-line. So... it's advanced 2 deg from what the can card recommended. I measured and have 106 deg intake center-line after advancing the crank sprocket 8 deg, the cam card calls for 108.. and the intake opening at .050 on the lifter is now at 26 deg, the cam card is 24 deg.. so the math jives between the two measurements... 2 deg. So the two measurements tell me I advanced the cam 2 deg from what Comp recommends.... right ? from 108 center-line to 106 center-line Which what I understand, 104-106 is what the guys on the board would like to see ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I used the intake , the second lifter from the front on the drivers side ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: DonnieLawson]
#2336843
07/14/17 11:19 AM
07/14/17 11:19 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Not saying it couldnt happen, but I have never had to advance a 108 cam 8 degrees to get it "back" to 106. Please double check all your readings and especially TDC. Its basically saying they had the cam at 114 degrees, which again, sh*t happens, but I find it hard to believe. I have put in a lot of Comps, and have never had that issue. I also vote for a safe and generic 104* install.2* is hardly noticable, but 104 is a great "safe and happy" spot on most 108 cams. Best of luck.
RIP Monte Smith
[Re: CompWedgeEngines]
#2336850
07/14/17 11:31 AM
07/14/17 11:31 AM
DonnieLawson
Middletown , Ohio
That's why I posted it... I thought it was pretty far out. I will go through remeasuring again today...It won't take long with the engine still being on the stand I did recheck the piston TDC before my last adjustment.. Wish me luck ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: DonnieLawson]
#2336867
07/14/17 12:15 PM
07/14/17 12:15 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It is what it is....... You degreed it...... You triple checked it.
You're good to go.
What you found is exactly why they should always be checked.
If you feel like you need to prove it to yourself one more time, degree the exhaust lobe. It should now be at 110.
Fwiw, I don't really rely on the cam card info to determine if the cam is in correct by the open/close points. I use the degree wheel to determine the open/close points, then calculate the actual duration @.050, then use that figure to come up with the theoretical c/l of the lobe...... Then move it to where I want it(if necessary). Ideally, my measured duration @.050 number and the cam card agree with each other, but they don't always....... Especially with rollers.
I guess what I'm saying is, I don't just use one reference point on the cam card(in your case, intake opening) to determine if the cam is where I want it.
[Re: Clanton]
#2336875
07/14/17 12:29 PM
07/14/17 12:29 PM
fast68plymouth
So. Burlington, Vt.
1 tooth on the cam gear is 8* so you may be 1 tooth off there or you can advance it like that as your 106 if this helps any. One tooth is 14deg on the degree wheel.
[Re: fast68plymouth]
#2336889
07/14/17 01:08 PM
07/14/17 01:08 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
1 tooth on the cam gear is 8* so you may be 1 tooth off there or you can advance it like that as your 106 if this helps any. One tooth is 14deg on the degree wheel. 14.4 ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) 720 crank degrees / 50 cam teeth Joe
Without Data, you’re just another guy with an opinion.
[Re: DonnieLawson]
#2336905
07/14/17 02:20 PM
07/14/17 02:20 PM
fast68plymouth
So. Burlington, Vt.
When you move the cam, obviously the dot on the top gear isn't going to be straight down anymore..... You "moved" it.
Lifter on the left is an 821(standard series), lifter on the right should be a 2921(performance series).
[Re: DonnieLawson]
#2337337
07/15/17 01:39 PM
07/15/17 01:39 PM
fast68plymouth
So. Burlington, Vt.
Okay, let me rephrase it........
None of the cam companies manufacture flat tappets. They buy them.
The lifter on the left is made by Stanadyne, and is what Comp sold under part number 821-16 for years. They are a one piece "solid" lifter...... And they're heavy.
The lifter on the right is made by Hy-Lift Johnson, and used to be what you got when you bought 2921-16. They are a multi-piece design and are lighter than the Stanadyne part.
#2337496
07/15/17 06:44 PM
07/15/17 06:44 PM
DonnieLawson
Middletown , Ohio
Teachin an old dog new tricks.... I really appreciate everybody's help..... That's what makes these boards so awesome ! I painted the block today with Por15 engine paint...It looks good, I just hope it holds up. It looks glossier then the spray bomb stuff I've always used... Liquid Purity ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) The purist may not like it... but I do for my application. It's Hemi Orange I never thought I would brush paint an engine
#2337527
07/15/17 07:36 PM
07/15/17 07:36 PM
Cab_Burge
Any idea on who made the Federal Mogul hydraulic lifters ten + yrs. ago for both SB and BB Mopars ?
