A/F set up help #2330989
07/03/17 08:23 PM
07/03/17 08:23 PM
plainwell,michigan
1fastaspen Offline OP
plainwell,michigan
Okay I got an aem a/f set up and I can't get this this to read at an idol it just says it's lean and shows no numbers if I bring it up around 1500 rpm it's at 17-18 I got a good ground and a full 12 volt power supply anyone else have this problem and if so what was the cure and yes this was a brand new in the box unit
75 duster 440 in the works
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2330991
07/03/17 08:26 PM
07/03/17 08:26 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If its real close to the exit of the exhaust it may not read until you get some RPM and exhaust flow, otherwise it will read a little bit of fresh air at low RPM. I have the same issue with my innovate LC2 when my exhaust dumps are open.
68 Barracuda Formula S 340
Re: A/F set up help [Re: 1fastaspen] #2330994
07/03/17 08:33 PM
07/03/17 08:33 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I had the same issue but once I adjusted the idle mixture screws it came right in. Did you try adjusted the idle mixture screws?
Re: A/F set up help [Re: 1fastaspen] #2331007
07/03/17 08:56 PM
07/03/17 08:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Did you index the o2 meter/sensor to outside air befor running?
Re: A/F set up help [Re: markz528] #2331008
07/03/17 08:56 PM
07/03/17 08:56 PM
plainwell,michigan
plainwell,michigan
Yes I had them backed out like three turns lol and no change it's got an exhaust on it dumps at the rear tires and the sensor is about 6 to 7 inches past the end of the collector but it has short collectors on it
71 pro street cuda
Re: A/F set up help [Re: Clanton] #2331018
07/03/17 09:21 PM
07/03/17 09:21 PM
plainwell,michigan
plainwell,michigan
Supposedly this one needs no calibration
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331034
07/03/17 10:09 PM
07/03/17 10:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Look for upstream air leaks.
Re: A/F set up help [Re: FastmOp] #2331040
07/03/17 10:26 PM
07/03/17 10:26 PM
plainwell,michigan
plainwell,michigan
I've looked at everything I can think of I even unhooked the evac system and no change but at 1500-2000 rpm it starts to read
71 pro street cuda
Re: A/F set up help [Re: FastmOp] #2331044
07/03/17 10:29 PM
07/03/17 10:29 PM
plainwell,michigan
plainwell,michigan
Like a push or suck of air
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331046
07/03/17 10:35 PM
07/03/17 10:35 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Does this help?
It says the O2 sensors are temperature sensitive.
http://www.aemelectronics.com/files/instructions/30-4100%20Digital%20Wideband%20UEGO%20Gauge.pdf
Re: A/F set up help [Re: Sammy] #2331048
07/03/17 10:37 PM
07/03/17 10:37 PM
plainwell,michigan
plainwell,michigan
Yes I did read that I'm going to let it run tomorrow and check the temp to see where it's at
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331050
07/03/17 10:43 PM
07/03/17 10:43 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Don't worry about what it reads at idle. Set the idle where the engine likes it and don't even look at the O2. It doesn't matter. The preferred idle mix on different engine combos is all over the place. Besides, there are several other factors that could affect the readings and confuse the issue.
Does your engine have much lope? If so, then the more lope at idle you have, the more that will confuse your O2 readings at idle.
Master, again and still
Re: A/F set up help [Re: DaveRS23] #2331053
07/03/17 10:47 PM
07/03/17 10:47 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I agree, I use a LM-2 on my drag car and I din't pay much attention to the idle readings
Re: A/F set up help [Re: dartman366] #2331059
07/03/17 10:56 PM
07/03/17 10:56 PM
plainwell,michigan
plainwell,michigan
It has a lot of lope
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331066
07/03/17 11:08 PM
07/03/17 11:08 PM
AndyF Offline
AndyF  Offline
Try it in a daily driver with a stock cam and I bet it will work.
The exhaust system has to be totally sealed up before you can trust anything the O2 sensor tells you. Any tiny air leak and it will read lean. You probably have some header leaks that you don't know about or you have a pan evac system that is sucking air into the exhaust. If you have a big cam then that will usually read lean and if you have a bit of misfire at idle it will read lean.
Re: A/F set up help [Re: 1fastaspen] #2331067
07/03/17 11:08 PM
07/03/17 11:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's the Evac. That's a no no with a wide band
Re: A/F set up help [Re: FastmOp] #2331072
07/03/17 11:20 PM
07/03/17 11:20 PM
plainwell,michigan
plainwell,michigan
I unhooked it and sealed it off
71 pro street cuda
Re: A/F set up help [Re: 1fastaspen] #2331086
07/03/17 11:36 PM
07/03/17 11:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Check your header gaskets. I use ultra copper on my stuff. I would make sure it's not getting air up stream
Re: A/F set up help [Re: 1fastaspen] #2331144
07/04/17 02:20 AM
07/04/17 02:20 AM
Cab_Burge Online work
Cab_Burge  Online Work
What brand and how old is this unit?
Re: A/F set up help [Re: Cab_Burge] #2331202
07/04/17 09:20 AM
07/04/17 09:20 AM
plainwell,michigan
plainwell,michigan
I will look for air leaks today and it's an aem with the Bosch sensor and it's brand new
71 pro street cuda
