Dash led replacement bulbs #2330329
07/02/17 08:06 PM
07/02/17 08:06 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Anyone have any current #s,brands,best place to buy and how many for a 70 RR dash??Thanks
Re: Dash led replacement bulbs [Re: 70RR383] #2330430
07/02/17 11:12 PM
07/02/17 11:12 PM
not a guarantee but www.classicindustries.com has a myriad of small parts (& other parts). If you make a small purchase from them (online) then several weeks later their comprehensive Mopar specific pricey catalogue will arrive in your mailbox unannounced for free & it is a treasure trove of pics etc (a reference manual). you can purchase that first item (maybe bulbs) online.
Re: Dash led replacement bulbs [Re: 70RR383] #2330431
07/02/17 11:14 PM
07/02/17 11:14 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't remember part numbers but superbrightleds has led 194 equivalents.
I used them in the dash on my Dakota. Bright vibrant blue LEDs look good at night they have all the colors available.
**Photobucket sucks**
Re: Dash led replacement bulbs [Re: 70Cuda383] #2330481
07/03/17 01:27 AM
07/03/17 01:27 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you put LEDs in the dash, will the dimmer still work with them?
Re: Dash led replacement bulbs [Re: 70RR383] #2330557
07/03/17 09:58 AM
07/03/17 09:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Not very well. Mine will dim slightly then just completely black out. If I had to guess, I'd say that I have control over brightness between 9-12 bolts but below 9v the leds just cut out
Re: Dash led replacement bulbs [Re: 70RR383] #2331139
07/04/17 02:05 AM
07/04/17 02:05 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Doug, I bought mine prepackaged from Herb's Parts. I only needed 4 for my E-body Rallye dash and I believe there was 9 in the pack, for 23.00. A little pricey, but they work great, and are fully dim-able thru the full range of motion on the dimmer switch.
They come prepackaged for certain ranges of years for different bodies, A, B, E etc.
Re: Dash led replacement bulbs [Re: 318 Stroker] #2331186
07/04/17 05:34 AM
07/04/17 05:34 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
These are SuperBrightLeds. Don't remember the #'s of the bulbs I chose, that was ~4 yrs ago.
My back is out at the moment and can't get under the dash to get any #'s, may be able to dig in my receipts.
PS: well! photobucket finally shut me down, back to the file manager.
Re: Dash led replacement bulbs [Re: 70RR383] #2331188
07/04/17 06:33 AM
07/04/17 06:33 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Superbrightleds.com is who I used. It's a one-size-fits-all for that type socket. There is a database on their site that tells you what you need. I used them. They dim ok. They have fantastic customer service and you can return anything.
FYI, for rear taillight/brake lights. The best is LEDTRONICS.
I’m listening.
Re: Dash led replacement bulbs [Re: 70RR383] #2331446
07/04/17 04:40 PM
07/04/17 04:40 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Re: Dash led replacement bulbs [Re: 70RR383] #2331475
07/04/17 05:30 PM
07/04/17 05:30 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Advance Auto Parts carries Sylvania LED's in all sorts of sizes.
Nautilus Racing-
Re: Dash led replacement bulbs [Re: 70RR383] #2332170
07/05/17 10:12 PM
07/05/17 10:12 PM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
I like superbrightleds for my 12v bulbs.
You factory service manual will tell you what number bulbs are in the various places in your car, then you can cross them on their site.
Re: Dash led replacement bulbs [Re: Stroker] #2332322
07/06/17 03:52 AM
07/06/17 03:52 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Here's the Superbrightled bulb i used. They're cool white, the blue comes from the lens cover in the dash.
https://www.superbrightleds.com/vehicle/...0&year=1970
