Re: Dash led replacement bulbs
[Re: 70RR383]
#2330430
07/02/17 11:12 PM
07/02/17 11:12 PM
RapidRobert
not a guarantee but www.classicindustries.com has a myriad of small parts (& other parts). If you make a small purchase from them (online) then several weeks later their comprehensive Mopar specific pricey catalogue will arrive in your mailbox unannounced for free & it is a treasure trove of pics etc (a reference manual). you can purchase that first item (maybe bulbs) online.
[Re: 70RR383]
#2330431
07/02/17 11:14 PM
07/02/17 11:14 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't remember part numbers but superbrightleds has led 194 equivalents.
I used them in the dash on my Dakota. Bright vibrant blue LEDs look good at night they have all the colors available.
**Photobucket sucks**
[Re: 70RR383]
#2330557
07/03/17 09:58 AM
07/03/17 09:58 AM
70Cuda383
Marysville, O-H-I-O
Not very well. Mine will dim slightly then just completely black out. If I had to guess, I'd say that I have control over brightness between 9-12 bolts but below 9v the leds just cut out
[Re: 70RR383]
#2331139
07/04/17 02:05 AM
07/04/17 02:05 AM
Posts: 4,321 St. Louis, Mo
318 Stroker
St. Louis, Mo
Doug, I bought mine prepackaged from Herb's Parts. I only needed 4 for my E-body Rallye dash and I believe there was 9 in the pack, for 23.00. A little pricey, but they work great, and are fully dim-able thru the full range of motion on the dimmer switch.
They come prepackaged for certain ranges of years for different bodies, A, B, E etc.
[Re: 318 Stroker]
#2331186
07/04/17 05:34 AM
07/04/17 05:34 AM
Posts: 1,805 ky hills
thehemikid
ky hills
These are SuperBrightLeds. Don't remember the #'s of the bulbs I chose, that was ~4 yrs ago. My back is out at the moment and can't get under the dash to get any #'s, may be able to dig in my receipts. PS: well! photobucket finally shut me down, back to the file manager.
[Re: 70RR383]
#2331188
07/04/17 06:33 AM
07/04/17 06:33 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Superbrightleds.com is who I used. It's a one-size-fits-all for that type socket. There is a database on their site that tells you what you need. I used them. They dim ok. They have fantastic customer service and you can return anything.
FYI, for rear taillight/brake lights. The best is LEDTRONICS.
I’m listening.
[Re: 70RR383]
#2331475
07/04/17 05:30 PM
07/04/17 05:30 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Advance Auto Parts carries Sylvania LED's in all sorts of sizes.
[Re: 70RR383]
#2332170
07/05/17 10:12 PM
07/05/17 10:12 PM
Posts: 2,271 central IL reg Nov 18, 1999
Stroker
I like superbrightleds for my 12v bulbs. You factory service manual will tell you what number bulbs are in the various places in your car, then you can cross them on their site.
