Re: Best combo for 600 HP Street Strip Car?
[Re: Dart451]
#2327778
06/27/17 11:15 PM
06/27/17 11:15 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
Plus and minus to the 440 or 400 block combo.
My preferred engine: The 383/400 block engine is overall less wide and less tall. This means actual room for your hands and socket/ratchet to change spark plugs on the passenger side. Also gives you more hood clearance, which is great. 383/400 block also weighs less, and the 400 block has stronger main webbing as mentioned. More room for header clearance. I personally think they look better also, more compact. Downside, intake selection has less choices, but enough to get the job done. No max wedge crossram, unless you run stage 6 mopar heads.
The 440 block engine has the most selection for intake manifolds, and is probably a little easier to build. However the 440 has downsides: block main webbing is not as strong, heavier, wider, taller, less clearance to work on the passenger side spark plugs (really non existent for #2, 4 cylinders). The crappy clearance issues for the spark plugs/headers, and less hood clearance using a 440 block is enough to really consider building a 383/400 based engine in my book. Note: Small block mopars have awesome spark plug access, way smaller overall size, weight...worth considering a 408 stroker type build.
I personally have based 440 based engine 505 stroker, flywheel dyno'd 620 HP @ 5900 / 620 torque @ 4800, 4.25 stroke/7.1 Rod, Keith Black forged flat top pistons, A&A max wedge cross ram with two 600 cfm Edelbrock carbs, Edelbrock RPM heads, CNC ported by Modern Cylinder Head, Bullet solid flat tappet cam 259/263 @ 0.050, nearly .600 lift, 108 centerline, BHJ balancer, TTI 2 inch headers, 10.5 compression. Never run down the quarter but its super fun and fast enough. Will run on pump gas but likes 100 or 110 leaded octane better with more advance like 35 degrees. 4:10 Dana, with A-1 4800 stall 8 inch converter, and Pro-Trans full manual 727. Installed in my 1964 Plymouth Savoy, street legal and driven often. Yes...I hate changing the spark plugs on the passenger side.
[Re: Dart451]
#2328012
06/28/17 12:06 PM
06/28/17 12:06 PM
Thumperdart
State of confusion
Trying to keep everything on time and in budget is the biggest goal. Plan on shifting at 6000 rpm will talk to machine shop this morning and see if they have other options besides eagle.
Car already has a good size scoop. Don't fall into the dual-plane craziness.............
[Re: Dart451]
#2328053
06/28/17 01:30 PM
06/28/17 01:30 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
The trans stall is to high and eliminates any theoretical advantage of a dual plane.
Summit single plane intake pricing
Weiand team G $270 Victor 300.60 Torker 303.52 Trick Flow 349.97
Not sure how they really stack up. Will have to research more. Anything but the Team G.
[Re: an8sec70cuda]
#2328062
06/28/17 01:54 PM
06/28/17 01:54 PM
Thumperdart
State of confusion
Not sure how they really stack up. Will have to research more. Anything but the Team G. Especially on low decks.............
[Re: Dart451]
#2328065
06/28/17 02:04 PM
06/28/17 02:04 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Team G is garbage on a RB also!!!!! The only thing there good for is the scrap pile.
Have a great day Iowan
"obsolete is neat"
[Re: Dart451]
#2328069
06/28/17 02:12 PM
06/28/17 02:12 PM
fast68plymouth
So. Burlington, Vt.
I'm with Andy on this one.
Get the TF.
IMO, the only TG that was worth anything was the RB 4500 version.
The low deck 4500 version wasn't too bad if you welded up the bolt reliefs in the 4 inner runners and ported that area to get rid if the choke point.
[Re: fast68plymouth]
#2328111
06/28/17 03:56 PM
06/28/17 03:56 PM
Thumperdart
State of confusion
Get the TF.
The low deck 4500 version wasn't too bad if you welded up the bolt reliefs in the 4 inner runners and ported that area to get rid if the choke point. Those were crazy restricting for sure but after that extra work how'd to get the bolts in............They were stupid tight as cast.........
[Re: Thumperdart]
#2328116
06/28/17 04:03 PM
06/28/17 04:03 PM
an8sec70cuda
Get the TF.
The low deck 4500 version wasn't too bad if you welded up the bolt reliefs in the 4 inner runners and ported that area to get rid if the choke point. Those were crazy restricting for sure but after that extra work how'd to get the bolts in............They were stupid tight as cast......... Probably had to use a small allen head bolt, or something similar.
[Re: Dart451]
#2328210
06/28/17 07:48 PM
06/28/17 07:48 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
I run a 440 source 505 , 4.25 stroke 7.1 rod . 11.0:1 . 272@050 solid flat tappet , .600 lift . In my Satellite has gone 10.53s and over 126mph best so far . So around 615 flywheel hp .But this does run a 5000 stall and 4.1 gear . This is my daily that I also bracket race . I went Dougs 2"headers - way better plug access over the 1 7/8 hookers . I have Source CNC heads by Modern . Has only been running since January but no issues other than getting the 4150 carb right . I shift at 6000 trap 66/6700 , 28"radial slick There would be more hp in a roller cam , better heads and a 4500 carb but I am happy
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: an8sec70cuda]
#2328258
06/28/17 08:55 PM
06/28/17 08:55 PM
Thumperdart
State of confusion
Get the TF.
The low deck 4500 version wasn't too bad if you welded up the bolt reliefs in the 4 inner runners and ported that area to get rid if the choke point. Those were crazy restricting for sure but after that extra work how'd to get the bolts in............They were stupid tight as cast......... Probably had to use a small allen head bolt, or something similar. I think it's a "secret"............
[Re: Dart451]
#2328312
06/28/17 10:38 PM
06/28/17 10:38 PM
fast68plymouth
So. Burlington, Vt.
I guess I didn't realize it needed an answer.
In my case, I didn't have the recesses in the outside of the runners filled in completely in the area directly adjacent to the bolts.
I did a little clearancing around the bolt area and test fit the intake and made sure I could get all the bolts in prior to doing any porting in the runners, and just didn't open them up fully at the bottom where it started to feel thin. I still ended up barely dimpling one of them...... And I smeared a little JB weld on the outside to seal any possible leak.
I used header bolts with the heads ground a little shorter in those 4 holes.
This all happened quite a long while ago, but as I recall the intake mod was worth over a tenth on a friends S/G car.
[Re: tex013]
#2328345
06/28/17 11:38 PM
06/28/17 11:38 PM
Posts: 4,700 Wichita
GY3
Wichita
Tex Very impressive!
[Re: tex013]
#2328349
06/28/17 11:47 PM
06/28/17 11:47 PM
Posts: 142 Chattanooga, TN
KDY
Chattanooga, TN
Tex I obviously have the wrong daily driver!
#2328355
06/28/17 11:56 PM
06/28/17 11:56 PM
Thumperdart
State of confusion
This all happened quite a long while ago, but as I recall the intake mod was worth over a tenth on a friends S/G car. Good info and we are lucky to have manifolds w/a hp design in mind more than a fitment thing............
