Newer style radiator salvage yard search for an a-body help #2327060
06/26/17 06:00 PM
06/26/17 06:00 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Anyone here recommend a radiator from the salvage yard that would fit in an abody? I'm going this weekend to search
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327062
06/26/17 06:04 PM
06/26/17 06:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'd be better off measuring what you have and seeing what'll fit. Make a sketch with the measurements written down. Location and diameter of the hose connections,
BTW, A body is a fairly useless hint as to what you need.
What year, what engine, which A body, with or without AC.
Don't be the exception.
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327076
06/26/17 06:44 PM
06/26/17 06:44 PM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
Just bought a new one from Pep Boys a few weeks ago for my '68 /6 Dart. Spectra CU526, $170 out the door. It's 22". Had to order hoses from a '73 and up with AC. Lower hose fit well. Upper hose should have, but was off just enough that it had a kink in it. Ended up modifying my old lower hose from the 18" radiator for the upper.
Re: Newer style radiator salvage yard search for an a-body help [Re: SIX225] #2327087
06/26/17 07:03 PM
06/26/17 07:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There were three sizes of A-Body radiators, 18", 22", and later 26", so that may help us out a little to see what you actually have... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327097
06/26/17 07:19 PM
06/26/17 07:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You forgot the differences in water pump inlets
Ac vs non AC
V8 vs /6
Heck of a lot more than just three sizes in the differences.
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327098
06/26/17 07:20 PM
06/26/17 07:20 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
+1 to Supercuda's advice
+1 to Rhinodart's post
..and knowing the engine will help too.
A 'newer' style radiator will have square top tank cross section.
Re: Newer style radiator salvage yard search for an a-body help [Re: Mattax] #2327158
06/26/17 09:35 PM
06/26/17 09:35 PM
IN
ahy Offline
ahy  Offline
IN
With radiators, time and maintenance matter. Not sure you will find a good usable one in a JY. Nothing against JY's... I shop there also. I just don't think it is a very promising place to find a serviceable radiator unless you want a core to have rebuilt.
If low cost is the goal, suggest a Champion aluminum or AP store replacement. I have run both on a PU and the Champion worked better (painted black).
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327628
06/27/17 06:04 PM
06/27/17 06:04 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
440. Pass. Side water pump. 22"core
Re: Newer style radiator salvage yard search for an a-body help [Re: ahy] #2327771
06/27/17 11:01 PM
06/27/17 11:01 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer
Re: Newer style radiator salvage yard search for an a-body help [Re: TJP] #2327833
06/28/17 12:45 AM
06/28/17 12:45 AM
UP
finn Offline
finn  Offline
UP
Me too.
I've used several cheap aluminum aftermarket radiators in my fleet.
There's no advantage to crawling the yards looking for a used up radiator that's probably no better than what you have.
Sort of like buying used brake shoes.
Re: Newer style radiator salvage yard search for an a-body help [Re: finn] #2327951
06/28/17 10:25 AM
06/28/17 10:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can think of at least one. Years ago I helped a friend put a V8 into a Chevy Luv.
We measured out the available space for a radiator, hose locations and diameters then went to the boneyard and started measuring. Believe it or not but the radiator out of an A100 with a /6 met the needs, we bought it and used it for mockup purposes. Turns out it was in good enough shape just to keep using it. So for mock up it has it's uses.
Re: Newer style radiator salvage yard search for an a-body help [Re: WS68SSC] #2327964
06/28/17 10:45 AM
06/28/17 10:45 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
iagree
Depends on what your doing, and who made it when. I've gone through 3 aftermarket radiators on my G.Wagoneer. Daily driver - moderatel hard use. The original fit better, was made better, and was well worth patching (in comparison). I finally have a repop that appears to be almost as good as the original. We'll see how good the quality of the soldering is over the next year or two.
