Re: Engine swap. Which is really easier?
[Re: da50r]
#2324960
06/21/17 10:49 PM
06/21/17 10:49 PM
Posts: 20,742 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
They can go in from the bottom if you have an engine hoist. You will need a way to support the front of the car and a dolly cart to roll it around on. A member here posted this awhile back. https://youtu.be/nam9tta49q8
[Re: da50r]
#2324969
06/21/17 11:06 PM
06/21/17 11:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You told us everything but what body it is.
Back when I swapped a 360 in place of a 225 in my 72 Dart there were no conversion mounts so I put a later style K member in.
I pulled the /6, then pulled the old K, then put in the new K, then put in the new engine and trans. Took me a full day but I got it done, had to as I was driving it to work the next day.
[Re: Neil]
#2324992
06/21/17 11:33 PM
06/21/17 11:33 PM
Posts: 2,628 Middle TN
da50r
Middle TN
They can go in from the bottom if you have an engine hoist. You will need a way to support the front of the car and a dolly cart to roll it around on. A member here posted this awhile back. https://youtu.be/nam9tta49q8 This is what I think I'll do since I'm swapping K members, brakes, spindles, etc.
[Re: da50r]
#2325006
06/21/17 11:51 PM
06/21/17 11:51 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
I did a /6 to 318 swap once. Without a lift it's easiest to pull the engine and trans first, then put the body on jackstands and drop the K-frame.
No longer taking $h!t from anyone!
[Re: da50r]
#2325147
06/22/17 11:09 AM
06/22/17 11:09 AM
Posts: 12,252 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In cases like this I always put it in from the bottom. It is much easier to tidy up all the odds and ends like wiring, hoses and such. But you will need a platform to hold the engine/tranny.
I have used a cherry picker before to do this. You will need to fashion a pair of extensions to attach to the bumper bracket mounts on the frame. And you will need to raise the rear and set it on something stable so that the body is roughly level when mating the K to the body.
Master, again and still
[Re: da50r]
#2325246
06/22/17 02:44 PM
06/22/17 02:44 PM
Posts: 18,263 Charlotte, NC
Orange_Crush
Belieber!
Belieber!
Charlotte, NC
Bottom is considerably easier.
Unbolt the LCAs, remove the torsion bars, unbolt the K-frame and transmission mount and lift away.
From the top, there's a lot of jockeying and it gets pretty tough to do if you don't have another set of hands.
1970 Dodge Charger R/T Hemi Orange U-code 4-speed 1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
