trunk lid decal #2322637
06/17/17 02:28 PM
06/17/17 02:28 PM
mass
raybee Offline OP
raybee  Offline OP
mass
Getting eady to install the trunk lid decal on my 70 roadrunner, is there a certin measurment from the top and bottom lines or just center it? also on the 440-6 decal on the hood? thanks for the help.
Re: trunk lid decal [Re: raybee] #2322642
06/17/17 02:46 PM
06/17/17 02:46 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Which decal?
Re: trunk lid decal [Re: raybee] #2322653
06/17/17 03:19 PM
06/17/17 03:19 PM
mass
raybee Offline OP
raybee  Offline OP
mass
The decal that goes from rear quarter extension to the other quarter extension
Re: trunk lid decal [Re: raybee] #2322732
06/17/17 07:46 PM
06/17/17 07:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: trunk lid decal [Re: DAYCLONA] #2322734
06/17/17 07:53 PM
06/17/17 07:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: trunk lid decal [Re: DAYCLONA] #2322738
06/17/17 08:12 PM
06/17/17 08:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If your decal backing paper looks like this below? then the location is already determined for you, the red arrows indicating where the white backing paper of the decal lines up with the airgrabber door opening on the hood to locate the decal properly, just double check that the actual 440-6 lettering of the decal will "fall" within the main stripe on the hood and not too close on the edge of the stripe, make adjustments as needed...IIRC I gave you the hood stripe location several months ago?...good luck with your project
Mike
Re: trunk lid decal [Re: DAYCLONA] #2323036
06/18/17 01:19 PM
06/18/17 01:19 PM
mass
raybee Offline OP
raybee  Offline OP
mass
THANK YOU DAYCLONA, you have helped me out a lot on my restoration over the past 2 years
