727 stall converter bolt pattern #2322383
06/16/17 11:14 PM
06/16/17 11:14 PM
jacksonville,FLORIDA
slammedR/T Offline OP
Just got a new 9.5" billet stall converter for my 727 transmission. But I noticed the bolt configuration is different from what I'm used to. instead of 4 bolt hole pads the mounting pads have two bolt holes side by side in four positions making 8 bolt hole mounting. I have never seen this before, is there a matching flexplate for this bolting flange style? I have a small block mopar stroker engine with forged crank shaft.
Or did the converter company use the wrong billet front plate on my converter?
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 727 stall converter bolt pattern [Re: slammedR/T] #2322386
06/16/17 11:20 PM
06/16/17 11:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
different bolt size? two different sizes available.
Re: 727 stall converter bolt pattern [Re: slammedR/T] #2322389
06/16/17 11:22 PM
06/16/17 11:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have the square flex plate and use the bolt to the right.
Re: 727 stall converter bolt pattern [Re: J_BODY] #2322398
06/16/17 11:41 PM
06/16/17 11:41 PM
They are both the same size and that is an 8 bolt crank flange, I have a small block which uses 6 bolt crank flange.
racemagnum
Re: 727 stall converter bolt pattern [Re: Clanton] #2322399
06/16/17 11:42 PM
06/16/17 11:42 PM
Where did you get it from?
racemagnum
Re: 727 stall converter bolt pattern [Re: slammedR/T] #2322404
06/16/17 11:52 PM
06/16/17 11:52 PM
I think this flexplate will work
racemagnum
