Crank Shaft Pulley with ATI Dampner ??? #2321794
06/15/17 09:00 PM
06/15/17 09:00 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Having some issues with a stock crank shaft pulley lining up with the water pump and alt pulley
The Crank shaft pulley is sitting too far "forward" compared to the water pump and alt pulley
I suspect it's due to ATI dampner being a bit wider compared to stock ?,,,therefore making the pulley sit too far out.....
Any thoughts ??
Is there a different pulley I could use ?
I know companies like March, etc sell aftermarket stuff,,,but didn't know if something more "stock" was available ??
Thx,
Doug
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321795
06/15/17 09:04 PM
06/15/17 09:04 PM
AndyF Offline
AndyF  Offline
The pulley from Doty Machine fits with the ATI damper.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321806
06/15/17 09:32 PM
06/15/17 09:32 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
We pulled my brother's 340 out, put this in it's place. We used an ATI damper. Used the stock 340 pulleys. Everything lined right up. Go figure. shruggy
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321816
06/15/17 09:51 PM
06/15/17 09:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I found that out too. I used a March dual groove pulley set that they list for the fluid damper (10170 kit) but it was too shallow by about 3/8", so Andy sells a 3/8" spacer (AR140?) that worked, but I had to use longer pulley bolts (ARP 612-1500 1.5" long). The result was close, I think the crank pulley aligned with the power steering pulley, but the water pump pulley needed a thin shim to get everything aligned correctly. On the plus side, I have never thrown a belt yet even when hitting 7,200 RPM.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: AndyF] #2321819
06/15/17 09:57 PM
06/15/17 09:57 PM
jersey
Spaceman Spiff Offline
jersey
Stock diameter?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321822
06/15/17 10:00 PM
06/15/17 10:00 PM
KENTUCKY
KENTUCKY
Thanks everyone!! Appreciate all the info and pics
Andy,,,,I found the pulley on their website. I don't have the sprocket like setup you have,,,, just the ATI dampener. Think it will still fit ?? Will need to do some measurements on the Doty pulley from their website. Thx.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321825
06/15/17 10:13 PM
06/15/17 10:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
is it pushed in all the way?
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321838
06/15/17 10:26 PM
06/15/17 10:26 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
The ATI is thicker as mentioned. Andy is correct on using the DOTY pulley. There's a picture floating around somewhere showing the difference in a stock damper vs the ATI.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321849
06/15/17 10:42 PM
06/15/17 10:42 PM
KENTUCKY
KENTUCKY
Difference looks to be about 5/16" to get all the pulleys to line up. This is how much the stock pulley is off from the water pump and alt pulleys
Stock pulley is about 2 - 5/16 tall
I need something around 2" tall.
Hoping the Doty will work. Website doesn't give that particular measurement but sounds like Andy has had luck with it. Just wondering if the sprocket apparatus he pictures affects anything ??
Thx guys !!
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321850
06/15/17 10:42 PM
06/15/17 10:42 PM
AndyF Offline
AndyF  Offline
Here is the Doty + ATI combo compared to the OEM setup. Very close to correct alignment. I told MD to put a picture like this on his website but I don't think he ever did.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321853
06/15/17 10:45 PM
06/15/17 10:45 PM
KENTUCKY
KENTUCKY
Andy. YOU ARE THE MAN !! Exactly what I needed to see. That will work. Going to order one. Thx. Will see if the stock bolts work ? You look to have ARP in your picture
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321863
06/15/17 10:53 PM
06/15/17 10:53 PM
It depends on which ATI dampener (two ring or three ring, Chevy three bolt pattern or Mopar 6 bolt pulley pattern) your using to determine which pulley will work on your motor scope
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321867
06/15/17 10:57 PM
06/15/17 10:57 PM
jersey
jersey
The problem with the Doty pulley is, it's a smaller diameter than the stock pulley.
Turns the water pump slower. I think it's the cause of my low speed issue of running hot.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321875
06/15/17 11:11 PM
06/15/17 11:11 PM
KENTUCKY
KENTUCKY
I am using the 6 bolt mopar dampener.
The effective belt diameter on the stock pulley is 5-3/8,,,, the Doty is 5",,,so 3/8 differential
Hopefully this won't be a issue for me. Running a high vol pump,,, big radiator,,, and big electric fan.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321877
06/15/17 11:13 PM
06/15/17 11:13 PM
KENTUCKY
KENTUCKY
Motor made 660 HP on the dyno. Going into a 70 Challenger. Thx guys !! Doug😎😇
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321881
06/15/17 11:15 PM
06/15/17 11:15 PM
AndyF Offline
AndyF  Offline
Stock bolts won't work. You need much longer bolts, maybe 1.75 inches.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2321899
06/15/17 11:40 PM
06/15/17 11:40 PM
KENTUCKY
KENTUCKY
Thx Andy 😎
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: Spaceman Spiff] #2321906
06/15/17 11:54 PM
06/15/17 11:54 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Spiff,,,it's the other way around. whistling It's like the pulleys On the the top of the blower,Big on the bottom,,small on top.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: AndyF] #2321944
06/16/17 01:03 AM
06/16/17 01:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
FWIW, ATI makes like 10 different "Mopar" pulleys. There is only one that fits the stock pulleys.
Re: Crank Shaft Pulley with ATI Dampner ??? [Re: 69CHARGERMD] #2322467
06/17/17 01:13 AM
06/17/17 01:13 AM
KENTUCKY
KENTUCKY
Thx BSB67!! I will check with ATI.
