Dog dish hub cap removal #2318112
06/08/17 03:45 PM
06/08/17 03:45 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Okay, dumb question. How hard is it to remove the dog dish hubcap without scratching/damaging the finish on the wheel? Is there a tip to doing this? Thx
1970 Dodge Challenger T/A
Re: Dog dish hub cap removal [Re: jeff968] #2318114
06/08/17 03:52 PM
06/08/17 03:52 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Re: Dog dish hub cap removal [Re: jeff968] #2318116
06/08/17 03:53 PM
06/08/17 03:53 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I found an L shaped piece of scrap metal, put tape on the part that touches the wheel and pried the suckers off. Tougher putting them back on without denting them.
Re: Dog dish hub cap removal [Re: jeff968] #2318117
06/08/17 04:02 PM
06/08/17 04:02 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Mine pop back on by hand, just push along the perimeter.
Re: Dog dish hub cap removal [Re: superchuck] #2318134
06/08/17 04:50 PM
06/08/17 04:50 PM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
Originally Posted By superchuck
Use non-marring nylon/plastic instead
https://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html
Over time you'll get marring where the cap snugs on the rim, but that's no different from marks that trim rings make near the lip - can't be seen anyway
Re: Dog dish hub cap removal [Re: jeff968] #2318145
06/08/17 05:32 PM
06/08/17 05:32 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
My solution has always been a couple layers of black electrical tape over the end of a small pry bar or flat screw driver.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Dog dish hub cap removal [Re: jeff968] #2318163
06/08/17 06:16 PM
06/08/17 06:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The correct tool.
Re: Dog dish hub cap removal [Re: John_Kunkel] #2318409
06/09/17 11:34 AM
06/09/17 11:34 AM
moparx Offline
moparx  Offline
Originally Posted By John_Kunkel
The correct tool.
i made one similar to that using a long, junk screwdriver i heated and bent into a J shape, then coating it with several layers of plasti-dip. i still use a soft cloth doubled up as a backer on the wheel surface. sorry i don't have a pic, but it is a very simple and cheap tool to make.
beer
Re: Dog dish hub cap removal [Re: jeff968] #2320290
06/13/17 12:19 AM
06/13/17 12:19 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
I'm lazy and used a little wheel bearing grease on the tabs before I put the hubcaps on. Made it easier for me to get the caps off/on with the plastic/nylon tools and a rag. Don't use too much grease cause it will sling off.
Re: Dog dish hub cap removal [Re: John_Kunkel] #2320391
06/13/17 08:13 AM
06/13/17 08:13 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The correct tool.
Yep that's the tool. Used that when I had to bust tires for a living.
