727 trans brake #2319332
06/11/17 11:16 AM
06/11/17 11:16 AM
usa,pa
jkwedge540 Offline OP
usa,pa
Went to the track yesterday and the trans brake would not set immediately. Took a couple seconds to get it to second. Older a&a valve body. Not sure if it's in the brake or some where else.
Re: 727 trans brake [Re: jkwedge540] #2319341
06/11/17 11:32 AM
06/11/17 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do a quick check of the trans adjustments
but it sounds like the brake is the issue..
slow to activate is dirt or a crack in the
brake.. pressure could be low
wave
Re: 727 trans brake [Re: jkwedge540] #2319343
06/11/17 11:35 AM
06/11/17 11:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
couple of seconds is a long time.... as always check the wiring. Band adjustment and associated parts ok? Another possibility is that it is setting, but creeping due to fluid loss. When my old Tranzact brake would set, but move forward a few inches, it was time for seals.
Re: 727 trans brake [Re: MR_P_BODY] #2319345
06/11/17 11:37 AM
06/11/17 11:37 AM
usa,pa
usa,pa
Another issue I had was second to third shift . It was slow going into third. Could this be related too each other.
Re: 727 trans brake [Re: jkwedge540] #2319356
06/11/17 12:02 PM
06/11/17 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think so.. once the shifter is in either
second or third/drive the brake is not involved..
only in low/first gear(on MOST brakes.. there are
brakes that allow a second gear start)... look at
the line pressure
wave
Re: 727 trans brake [Re: jkwedge540] #2319494
06/11/17 05:37 PM
06/11/17 05:37 PM
A727Tflite Offline
A727Tflite  Offline
Clarify your first post. You said it took a couple seconds to second? Did you mean to "set" or to "second"?
Re: 727 trans brake [Re: A727Tflite] #2319503
06/11/17 06:06 PM
06/11/17 06:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also.. low fluid lever will act that way
wave
Re: 727 trans brake [Re: jkwedge540] #2319517
06/11/17 07:04 PM
06/11/17 07:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since 3rd gear is the front clutch and the front clutch is also used for the brake, I'd say it's likely. (Worn seals/rings, leakage)
Re: 727 trans brake [Re: John_Kunkel] #2319559
06/11/17 09:29 PM
06/11/17 09:29 PM
usa,pa
usa,pa
So the teflon seals are bad?
Re: 727 trans brake [Re: A727Tflite] #2319601
06/11/17 11:19 PM
06/11/17 11:19 PM
usa,pa
usa,pa
No it took a couple of seconds to set the brake.
Re: 727 trans brake [Re: jkwedge540] #2319687
06/12/17 01:51 AM
06/12/17 01:51 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You will have to drop the valve body, inspect the case for damage or cracks and do an air check on the front clutch port. It should produce a clunk sound when applied. Excessive air leaking is also a sign a something is failed or not put together right. If it appears to be OK, you could try another VB. Were it me, I would just get it out, air check it on the bench and/or pull the drum and look at it. Verify or fix it and try another VB if I don't see anything obvious.
Re: 727 trans brake [Re: jkwedge540] #2319698
06/12/17 02:10 AM
06/12/17 02:10 AM
A727Tflite Offline
A727Tflite  Offline
No mention of having a problem going in to reverse. The A & A brake, like others uses the front and rear clutch and the L/R band for the brake. You could also have an issue with the rear band servo. If you pull the valve body check the rear servo apply too. A rubber tipped blowgun should apply the band with no leakage. The front clutch apply the same - but you may hear some leakage because you are dealing with sealing rings and a bleed orifice.
Re: 727 trans brake [Re: jkwedge540] #2321344
06/14/17 11:22 PM
06/14/17 11:22 PM
usa,pa
usa,pa
The front band has nothing to do with it?
Re: 727 trans brake [Re: jkwedge540] #2321396
06/15/17 12:48 AM
06/15/17 12:48 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Front band has nothing to do with the brake, in a 3 speed. Front band applies to get it in to second gear. Releases on the shift to third. A slow to release band will affect the 2-3 shift.
Re: 727 trans brake [Re: jkwedge540] #2321517
06/15/17 09:28 AM
06/15/17 09:28 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have had this happen twice in the past 14 seasons of racing. Both times the solenoid was replaced and the problem was solved.
Re: 727 trans brake [Re: jkwedge540] #2321553
06/15/17 11:30 AM
06/15/17 11:30 AM
A727Tflite Offline
A727Tflite  Offline
After air checking I would have to agree with cl440. A recent experience with a CRT valve body leads me to believe either dirt or electrical issues with the solenoid.
Re: 727 trans brake [Re: A727Tflite] #2322344
06/16/17 09:03 PM
06/16/17 09:03 PM
usa,pa
usa,pa
Ok. The valve body in this trans is from 1991. Hate to take it out if all it is is a bad solenoid. It is the original one.the pan did not have anything in it. It was clean.is there a certain part of the trans I should concerntrate on . I have own this trans since 2002 and never had and issue with it. Rebuild it ever year .
Re: 727 trans brake [Re: jkwedge540] #2322420
06/17/17 12:15 AM
06/17/17 12:15 AM
A727Tflite Offline
A727Tflite  Offline
I'd call Rick at A & A and see what he says.
Re: 727 trans brake [Re: A727Tflite] #2322429
06/17/17 12:26 AM
06/17/17 12:26 AM
usa,pa
usa,pa
I check the trans solenoid. It doesn't seem to bang like before. Use to be able to hear it in the car when you pushed the button.
Re: 727 trans brake [Re: jkwedge540] #2322450
06/17/17 12:48 AM
06/17/17 12:48 AM
A727Tflite Offline
A727Tflite  Offline
You can try to clean it - take it off and find the bleed orifice and backflush it with brake clean. Doesn't take too much debris to cause a significant leak. I would have hoped there would be a screen on the fluid source side before the fluid got to the solenoid seat. 26 years ain't bad 😀 For a solenoid.
