Re: 727 trans brake
[Re: jkwedge540]
#2319341
06/11/17 11:32 AM
06/11/17 11:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Do a quick check of the trans adjustments but it sounds like the brake is the issue.. slow to activate is dirt or a crack in the brake.. pressure could be low
Re: 727 trans brake
[Re: jkwedge540]
#2319356
06/11/17 12:02 PM
06/11/17 12:02 PM
MR_P_BODY
Another issue I had was second to third shift . It was slow going into third. Could this be related too each other. I dont think so.. once the shifter is in either second or third/drive the brake is not involved.. only in low/first gear(on MOST brakes.. there are brakes that allow a second gear start)... look at the line pressure
Re: 727 trans brake
[Re: jkwedge540]
#2319517
06/11/17 07:04 PM
06/11/17 07:04 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Another issue I had was second to third shift . It was slow going into third. Could this be related too each other. Since 3rd gear is the front clutch and the front clutch is also used for the brake, I'd say it's likely. (Worn seals/rings, leakage)
Re: 727 trans brake
[Re: jkwedge540]
#2321396
06/15/17 12:48 AM
06/15/17 12:48 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Front band has nothing to do with the brake, in a 3 speed. Front band applies to get it in to second gear. Releases on the shift to third. A slow to release band will affect the 2-3 shift.
Re: 727 trans brake
[Re: jkwedge540]
#2322450
06/17/17 12:48 AM
06/17/17 12:48 AM
Posts: 3,087 Michigan
A727Tflite
You can try to clean it - take it off and find the bleed orifice and backflush it with brake clean. Doesn't take too much debris to cause a significant leak. I would have hoped there would be a screen on the fluid source side before the fluid got to the solenoid seat. 26 years ain't bad 😀 For a solenoid.
