Page 1 of 9 1 2 3 4 5 6 7 8 9
Still running hot in traffic with the new aluminum rad #231860
02/21/09 10:23 PM
02/21/09 10:23 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Well not only did I do the carb swap this week I swapped the radiators. I took the stock one and replaced it with an AFCO 26” x 18.5” cross-flow Aluminum radiator with a massive puller fan that stays on anytime the car has the key on. Only issue was the radiator cap- it didnt come with one so i took the old one off the old radiator and put it on the new radiator. (Doesnt fit, 16 lb and I need a 20 lb) Anyway, ran it down the freeway, did well, exited, sat in traffic 5-10 mins (stop-go) and the needle got over to the "H". I weasled out of traffic and got moving again and it went back down. Man, now im back to square one. What else could be causing this? What degree thermostat should i be running? Anything else I can do to try and keep it cool?
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231861
02/21/09 10:38 PM
02/21/09 10:38 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
So you don't have a gauge on it to know what the ACTUAL temp is?
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231862
02/21/09 10:52 PM
02/21/09 10:52 PM
The difference from the freeway to sitting in traffic is air speed(fan) & water pump speed. Most likely to be air speed . What do you have for a shroud/fan. What water pump?
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231863
02/21/09 10:54 PM
02/21/09 10:54 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
So I take it you are using an electric puller fan? Move the puller to the front and use it as a pusher and put it on a thermostatically controlled switch. Then add in a stock type fixed fan to your motor and your problems will go away. A fixed fan flows a decent amount of air at idle, and with the help of a pusher the two should not have any problem cooling that motor.
Re: Still running hot in traffic with the new aluminum rad [Re: goldmember] #231864
02/21/09 10:55 PM
02/21/09 10:55 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
No, interior is 100% stock/factory. Never got an actual temp gauge, I guess that is where I should start. I wanted to keep it as factory appearing as possible but I figure its time to get a new aftermarket gauge.
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231865
02/21/09 10:56 PM
02/21/09 10:56 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
No shrould, just aftermarket puller fan 3000 CFM i believe.
Unsure about the water pump.
Re: Still running hot in traffic with the new aluminum rad [Re: DaytonaTurbo] #231866
02/21/09 10:57 PM
02/21/09 10:57 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Well I cant do that b/c I have the AC condenser and the tranny cooler in the front of the radiator.
Let me go snap a few pics for you guys---
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231867
02/21/09 11:03 PM
02/21/09 11:03 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You don't even need a gauge in the car. Use a cooking thermometer in the radiator inlet ,let the car idle until the gauge reads hot and see how hot it is. Easy to find out if you have a real problem or not.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231868
02/21/09 11:10 PM
02/21/09 11:10 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
here they are, pardon the dirt, it needs to be detailed.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231869
02/21/09 11:18 PM
02/21/09 11:18 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
if it's the water pump==what aftermarket pump would you go with on a 440ci motor?
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231870
02/21/09 11:37 PM
02/21/09 11:37 PM
edelbrock or milodon water pump. I think that elec fan is not moving enough air especially with all the hardware in front of the radiator.
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231871
02/21/09 11:45 PM
02/21/09 11:45 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
with how it sits now-- what would you do? get a better fan setup? dual fans? move the condensor and tranny cooler?
Right now im looking at replacing the water pump and thermostat to a 160. Im also going to get the correct radiator cap Monday.
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231872
02/21/09 11:47 PM
02/21/09 11:47 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
is this the correct Edelbrock?
http://www.jegs.com/i/Edelbrock/350/8814/10002/-1
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231873
02/21/09 11:53 PM
02/21/09 11:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need at least a 180* stat. The stat doesn't do anything but bring the engine up to it's rated temp. Once it's open it doesn't effect the temp. I would go back to a factory fan, shroud and stock water pump set up that has worked for a lot of 440 set ups for a long time.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231874
02/21/09 11:55 PM
02/21/09 11:55 PM
All this nonsense about "puller and pusher." There is ONLY ONE WAY that air should ever go through a CAR radiator, and that is from front (of the radiator) to back.
MAKE SURE the fan is the correct type and is turning the correct direction. You should be able to see this by looking at the fan blades. The will be "cupped" on one side, and this is the side that they should "pull" to (Blades are like wings--they are more efficient in one direction than the other) Some fans will change direction just by changing the wiring polarity, and they will NOT WORK WELL when reversed!!!!
I know nothing of the track record of the specific fan you have, it simply may not be enough
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231875
02/22/09 12:00 AM
02/22/09 12:00 AM
You know it'd sure be easier if a good aftermarket W/P took care of this as the W/P would be a much easier install. Also I'd get a high flow 180 stat( drill a 1/16" hole in it for easy fillup). 160 is way too cool ex for a drag racer(& you are way above 160 degrees). The A/C condenser & trans cooler have to stay. I do not have the last word on fan advice but the old standby of a properly spaced(into the shroud) thermal clutch fan would be what I would do. there's just not enough air going thru the rad fins. EDIT yes that is the correct pump though I would check milodon & see if their pump is cheaper.
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231876
02/22/09 12:31 AM
02/22/09 12:31 AM
Central NC
gch Online content
gch  Online Content
Central NC
I use the mp fan and thermal clutch setup with a factory shroud and water pump for an a/c car.Never runs over 180 unless idling in the summer heat for an extended period of time.
Have you verified your ignition timing?Retarded timing can contribute to high temps
If I had to guess I would say your fan is either not pulling air or not pulling enough air.Make sure you clean the fins on your condenser as well to get the maximum amount of air through it.
Re: Still running hot in traffic with the new aluminum rad #231877
02/22/09 12:38 AM
02/22/09 12:38 AM
alberta
Publicbottle Offline
alberta
Or a simple test would be have the car running at idle and take a piece of paper and put it on the front of the rad and the fan drawing air in through the rad should make the paper stick.
I have the exact same AFCO set up as you for my 340 challenger, i dont have the car running yet but i am following this thread closely and i am waiting to hear what the fix is........
TK
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231878
02/22/09 12:39 AM
02/22/09 12:39 AM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
How old is the engine? as in is it the original build?
Also check to make sure that you really have an A/C water pump, there is a difference and what I found was that when you order an A/C pump most parts suppliers will supersede the A/C pump and send what ever and it will most likely be a non A/C pump. The factory service manual will have the specs of your pump impeller that you need.
I went thru a lot of hassle with my big block cooling when I found it to be the block was full of crap, I used the Mopar clutch fan with factory shroud A/C pump and flushed block, that car never bothered me again.
It would run at a consistent temp in all traffic.
My engine was a factory original with 70,000 miles in great shape cept for all the grud.
Re: Still running hot in traffic with the new aluminum rad [Re: gch] #231879
02/22/09 12:40 AM
02/22/09 12:40 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Put a thermal clutch fan on it with a shroud. Half the time, electric fans are garbage on the street. The extremely minimal power loss required to run a clutch fan is far easier to live with than overheating the engine. Run a viscous fan with a shroud.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
