DC sixpack for a 440 #2315497
06/03/17 10:05 AM
06/03/17 10:05 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Found this for sale recently, aluminum intake and carbs buddy says is a Direct Connection piece. Mechanical secondaries and fuel line runs down the opposite side to a conventional set up. Is this a race only setup or can this be run on the street? Throttle arm comes up between the secondary linkage rods, doesn't look right to me??
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: DC sixpack for a 440 [Re: busboy] #2315499
06/03/17 10:11 AM
06/03/17 10:11 AM
busboy Offline OP
busboy  Offline OP
Oops, sorry for the wonky pictures!
Re: DC sixpack for a 440 [Re: busboy] #2315505
06/03/17 10:30 AM
06/03/17 10:30 AM
busboy Offline OP
busboy  Offline OP
One more time.
Re: DC sixpack for a 440 [Re: busboy] #2315512
06/03/17 11:10 AM
06/03/17 11:10 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes they are the old DC released mechanical carbs
Re: DC sixpack for a 440 [Re: DAYCLONA] #2315528
06/03/17 12:03 PM
06/03/17 12:03 PM
busboy Offline OP
busboy  Offline OP
Thanks Dayclona, race piece or can they be run on the street? Any concerns with that linkage?
Re: DC sixpack for a 440 [Re: busboy] #2315561
06/03/17 01:14 PM
06/03/17 01:14 PM
MA
steve70 Offline
steve70  Offline
MA
A friend of mine had the same set up on his 70 Challenger R/T and drove it on the street all the time.
1970 Challenger T/A 4 speed
Re: DC sixpack for a 440 [Re: busboy] #2315593
06/03/17 02:34 PM
06/03/17 02:34 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
They are rare, and my favorite 3 2bbls carbs for any sixpack set-up especially on the street. Less particular drivers can benefit from having the vacuum modulate the throttle position for them with the stockers, but I never liked the way the vacuum secondary stock six pack reacted while opening and closing. I prefer to control the opening and closing of the outboards directly myself. There's a disconnected response that I always felt was funky with the vacuum secondary carbs with a resultant lag time from pedal position to throttle blade position. The worst thing about them in my book is that noticable bit of lag time the outboards have in closing immediately after letting off the gas pedal.
Those look like they could use a quality rebuild, and the linkage and fuel lines are unusual. Another lesser known aspect of these carbs is that unlike their factory installed counterparts, the outboards don't have idle circuits in them. The motor idles exclusively off the center carb. This makes getting the A/F ratio set up significantly easier too. The outboards also use common Holley jets in a traditional metering block arrangement to adjust fuel flow.
Curious what you gave for the set-up, as they are no longer available from Holley, and quality examples have become quite expensive.
I currently have a fresh set to install on my 493" motor, and a second set being converted to use 3 of the large bore outboard sized carb bodies with the center carb being modified to have a functional idle circuit. The throttle bores are also being increased in size and having an aerosol booster installed in them. They should flow significantly more than the stock factory or Direct Connection set-ups. It should be interesting to see how much the power output is affected for better or for worse with the higher flowing modified versions.
I absolutely love the way these carbs feel under foot.
Re: DC sixpack for a 440 [Re: jbc426] #2315596
06/03/17 02:42 PM
06/03/17 02:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've had a few sets and they work awesome. You have accelerator pumps on all 3 carbs which gives unreal response when you have them setup correctly. IMO they work much better than a vacuum setup. Running fuel lines is a bit of a PITA though.
Sheldon
Re: DC sixpack for a 440 [Re: busboy] #2315599
06/03/17 02:47 PM
06/03/17 02:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have run those on multiple motors / combinations over the years and love them. They are typically happier on a 440 but I have used them on 340's as well. The linkage posted is hokey.
The following pic's are the install on my 38 and have been on there for about 30 years
Re: DC sixpack for a 440 [Re: RUNCHARGER] #2315622
06/03/17 03:59 PM
06/03/17 03:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Truth! I ended up running individual -6AN fuel lines and -6AN Banjo fittings to each carb from my Bypass regulator. I also insulated the lines to keep heat out of them.
Re: DC sixpack for a 440 [Re: busboy] #2315658
06/03/17 05:47 PM
06/03/17 05:47 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
If you ever want to get rid of that throttle linkage, I will buy it! Just let me know.
A True Hybrid: Burns Gas AND Rubber!
Re: DC sixpack for a 440 [Re: fastnos] #2315743
06/03/17 11:06 PM
06/03/17 11:06 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
You could also piece that combo thru a speed shop back in the day,cheaper than dc.I done a couple of them years ago,worked great when set up right.Funny thing my old 70 cornet r/t was just dropped off today to get running after not been run in 3 years.got it running quickly but carbs need rebuilding leaking bad.
Re: DC sixpack for a 440 [Re: GarageDodge] #2315791
06/04/17 01:20 AM
06/04/17 01:20 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Ran these carbs for nearly 20 years all street driving, they were on my 440 when I found the car - different linkage than the one posted. After rebuilding the carbs, they worked flawlessly, instant throttle response with the accelerator pumps and adjustable to where you wanted the outboards to come in. I really mean my 440 was ferocious with the cam, headers, torque coverter that I had in the car, loads of laughs. Great carbs.
Re: DC sixpack for a 440 [Re: shakerjoe] #2316433
06/05/17 04:51 AM
06/05/17 04:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea instead of a double pumper carb you will have a triple pumper setup. grin Ron
Re: DC sixpack for a 440 [Re: busboy] #2316858
06/05/17 09:31 PM
06/05/17 09:31 PM
busboy Offline OP
busboy  Offline OP
Thanks for the info, what model of Holley carb are these? Are rebuild kits still available for them?
Re: DC sixpack for a 440 [Re: busboy] #2316943
06/06/17 12:22 AM
06/06/17 12:22 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The correct list numbers are 4782 and 4783. There is nothing special about required parts as the are common with a multitude of holley carbs. I normally "stock" the individual components due to their common use. The KITS normally cost 3x price wise
The hacked up linkage shown in your pic's needs to go way SOUTH IMO. And BTW if you choose not to buy the setup, please post the asking pric, location and a contact #
beer
Re: DC sixpack for a 440 [Re: TJP] #2316951
06/06/17 12:31 AM
06/06/17 12:31 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I used the standard rebuild kit for 6 pack - Holley 3-396 x 3 of course😁
Re: DC sixpack for a 440 [Re: busboy] #2317338
06/06/17 09:53 PM
06/06/17 09:53 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I like how they work on the track or street.
Re: DC sixpack for a 440 [Re: busboy] #2317619
06/07/17 01:14 PM
06/07/17 01:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
As with all Holley's, use the non-stick blue gaskets or get the Superformance gaskets to rebuild them. I always block the heat crossover and insulate the fuel supply lines to keep the heat out of the fuel, but I live in a moderate climate too. A wideband sure helps in getting the jetting and accelerator pump shots right.
Re: DC sixpack for a 440 [Re: busboy] #2318697
06/09/17 10:42 PM
06/09/17 10:42 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Chevrolet carbs had fuel inlets on the driver's side /with mechanical linkage . I've never seen a Mopar setup like that ? I could be wrong .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
