Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: ultrajosh] #2314569
06/01/17 02:05 PM
06/01/17 02:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
When you say dripping out of the bottom of the seal do you mean the gasket between the third member and housing?
I had a leak that I thought was the gasket and it ended up being the fluid was wicking around one of the four bottom studs that are under the fluid level seeping around the knurl that retains them shock shruggy
I had that third member out three or four times before finding that, it took some Mopar brand grey transfer case and rear end sealer on the knurls to fix it work It would leak around the knurl ands leak out behind the flat washer and nut and look like it was leaking from the gasket confused shruggy
Good luck, let us know what you find and do to fix it, you can fix it thumbs
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: Cab_Burge] #2314600
06/01/17 02:52 PM
06/01/17 02:52 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Had this same leak rear end of our 300 B. Pulled each lower stud, slathered with silicone, somewhat wary if would do the job because of inability to get a clean dry surface. However has so far done the job. If had not, would do again using PTFE/Teflon tape.
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: skicker] #2314604
06/01/17 03:00 PM
06/01/17 03:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By skicker
I'm trying to picture where your screwing these longer studs in for guide studs...???
Last and every 8 3/4 I ever messed with the studs were pressed in with a knurl from the inside. 64 up anyway...
That means the pig is already out and on the ground again to get inside the housing to swap out the studs to longer ones...Sure will make fixing the leak easier... runaway
I understand most here have great intentions when offering advise...but damn...To someone whose never done this and is truly trying to learn he is unbelievably confused now... fan
Your right, I was wrong.
Been a while since I have swapped gears on a 8 3/4" rear and yea it would be tough to pull the factory studs to install longer ones and not worth it. I was thinking it used bolts like the last rear I did. I have done more 9" and truck rears than I have 8 3/4 lately.
I don't think the OP is confused as he just got done doing this so he is more in tune with the job right now than any of us right at the moment.
I do remember needing to have the car up high so I could muscle that 3rd member from my chest into the car more than once years ago.
Same with 4 speeds on my chest first then into the bell housing.
I have done a lot work at home years ago where I don't have a trans jack.
I still have few 8 3/4 laying around.
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: Challenger 1] #2314876
06/01/17 11:04 PM
06/01/17 11:04 PM
IMGTX Offline
IMGTX  Offline
Not to highjack the thread but where did you get that Carrier box?
Me likey alot.
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: IMGTX] #2314937
06/02/17 12:51 AM
06/02/17 12:51 AM
Cincinnati, Ohio
Cincinnati, Ohio
I think mine are made by Jaz fuel cells? I bet several people make them now, but I am pretty sure Jaz was the first to make them.
Actually they came with new 9.5" rear ends I bought over the years from Mark Williams. I have bought too many from them. Racing top alcohol dragster you go through some rear ends.
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: skicker] #2314940
06/02/17 12:56 AM
06/02/17 12:56 AM
I agree, my mistake!
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: ultrajosh] #2315010
06/02/17 09:35 AM
06/02/17 09:35 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
15 years ago I would have just lifted it and it was in. The problem is that as we get older we/I don't have the arm strength. I feel for you. I was lucky last time, a younger guy lifted it in for me. I probably will not R&R another one in this life. I'm now 75
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: ultrajosh] #2315646
06/03/17 05:19 PM
06/03/17 05:19 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
MaMopar gave up on gaskets 25 years ago. Order one from the dealer and you get a tube of gear-lube-resistant RTV. Way to go. ONLY way to go!
Rick
Re: 8 3/4 swap in driveway, solo with jack stands - tips? [Re: ultrajosh] #2316669
06/05/17 04:31 PM
06/05/17 04:31 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Never used a gasket. Gear lube resistant sealer.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
