Plastic Prep-Grille Refinishing-Blast Grille?
#2310326
05/24/17 01:04 PM
05/24/17 01:04 PM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Whats a good method to strip spray bomb paint of a decent 71 Charger Plastic Grille?
I think some shops use Walnut shells to blast with?
Thansk in advance!
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
Re: Plastic Prep-Grille Refinishing-Blast Grille?
[Re: 440PURSUIT]
#2311659
05/26/17 06:12 PM
05/26/17 06:12 PM
440PURSUIT
DC, MD Suburbs
Ill try the oven cleaner method and advise.
[Re: 440PURSUIT]
#2312308
05/28/17 11:07 AM
05/28/17 11:07 AM
Posts: 1,083 Long Island, NY
70plymA34
Long Island, NY
i used brake cleaner and it worked, but i forgot which one i used (chlorinated vs non chlorinated.)
Super Commando
[Re: 440PURSUIT]
#2314047
05/31/17 08:13 AM
05/31/17 08:13 AM
440PURSUIT
DC, MD Suburbs
The oven cleaner worked great on the test grille and washed away with hot water.
Will try to post some pics today.
[Re: ScottSmith_Harms]
#2314902
06/01/17 11:59 PM
06/01/17 11:59 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I learned the hard way about 20 years ago, sprayed oven cleaner on a 71 Cuda grille to remove the argent. I left it to soak for a while and came back to find that It had melted the grille in multiple areas, it was a disaster.
Actual example for you right there! Like everything else, probably no where near as strong as it was back then. I remember when aircraft paint stripper felt like it was melting your skin off, now it barely even burns.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
