Plastic Prep-Grille Refinishing-Blast Grille? #2310326
05/24/17 01:04 PM
05/24/17 01:04 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
Whats a good method to strip spray bomb paint of a decent 71 Charger Plastic Grille?
I think some shops use Walnut shells to blast with?
Thansk in advance!
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2310350
05/24/17 01:46 PM
05/24/17 01:46 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Oven cleaner. The one with the yellow top is what I used. Spray it, wrap it up in a trash bag, strip it the next day. I did my grille this way.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2311659
05/26/17 06:12 PM
05/26/17 06:12 PM
DC, MD Suburbs
DC, MD Suburbs
Ill try the oven cleaner method and advise.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2311722
05/26/17 07:48 PM
05/26/17 07:48 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I wouldn't use oven cleaner to harsh & can possibly permeate the plastic,when its time to do mine going to caustic soda blast it.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 71GTX471] #2311978
05/27/17 01:09 PM
05/27/17 01:09 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I purchased a mini soda blaster and blasted mine. Worked really well and did not damage the plastic.
It's more difficult for the soda to remove urethane or enamel vs. lacquer. It's a breeze on parts painted with lacquer.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2312308
05/28/17 11:07 AM
05/28/17 11:07 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
i used brake cleaner and it worked, but i forgot which one i used (chlorinated vs non chlorinated.)
Super Commando
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2312323
05/28/17 11:25 AM
05/28/17 11:25 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Don't use chemicals on plastic, oven cleaner, brake fluid, etc. are a recipe for disaster. Has it worked for some? Yes. Is it potentially going to melt your grille or screw up your new paint job? Yes!
Media blasting with low pressure and fine media works great, I suggest soda blasting, but other medias will work as well, plastic would be my first choice over sand. Sand or glass media can damage the plastic.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: ScottSmith_Harms] #2312388
05/28/17 01:47 PM
05/28/17 01:47 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I haven't had any problems with oven cleaner, there are countless threads on others using the same method. After the paint is stripped and the grille is washed clean, I'm not sure how you would ruin the paint. Maybe if someone else has actual experience with oven cleaner ruining plastic they should chime in, otherwise it's just one of those things that sounds scary. Try it on a spare part or something beforehand and then make a decision if you want to buy a blasting kit instead of a $3 can of oven cleaner.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2312391
05/28/17 01:56 PM
05/28/17 01:56 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I have to agree with Scott. I've used oven cleaner with good success on a couple original plastic pieces. However, I used oven cleaner to strip a used lower valence insert and it caused the grey plastic substrate to turn yellow in some spots.
You just need to be careful and test it in a non-visible area. I would say that brake cleaner or brake fluid are too caustic for ABS, which is what these grills are made from. It will more than likely damage the plastic.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2312404
05/28/17 02:32 PM
05/28/17 02:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I learned the hard way about 20 years ago, sprayed oven cleaner on a 71 Cuda grille to remove the argent. I left it to soak for a while and came back to find that It had melted the grille in multiple areas, it was a disaster.
Actual example for you right there!
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: 440PURSUIT] #2314047
05/31/17 08:13 AM
05/31/17 08:13 AM
DC, MD Suburbs
DC, MD Suburbs
The oven cleaner worked great on the test grille and washed away with hot water.
Will try to post some pics today.
pics [Re: 440PURSUIT] #2314573
06/01/17 02:12 PM
06/01/17 02:12 PM
DC, MD Suburbs
DC, MD Suburbs
Here is the trash bag oven cleaner method. Hot Water out the hose nozzle wash the flakes away rather well.
Somebody laid on the spray bomb. Both these grilles had broken studs in the back so they were fit to test.
Re: pics [Re: 440PURSUIT] #2314816
06/01/17 09:53 PM
06/01/17 09:53 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Cool, glad it worked out for you. My Charger had a ton of cheap spray paint on it. Mine peeled away pretty easy but I had to pull out the loose pieces with a small needle nose that were down in the square recesses since they were just attached enough hot water wouldn't flush them off. I just took a fine scotch brite and warm soapy water and went over it well before I painted it.
Re: Plastic Prep-Grille Refinishing-Blast Grille? [Re: ScottSmith_Harms] #2314902
06/01/17 11:59 PM
06/01/17 11:59 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Like everything else, probably no where near as strong as it was back then. I remember when aircraft paint stripper felt like it was melting your skin off, now it barely even burns.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
