Re: Starters
[Re: jeebis44]
#2310560
05/24/17 08:35 PM
05/24/17 08:35 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Should fit no problem but you may need to put the main cable on first depending on what starter you get. I prefer the OEM Denso unit from Mancini. They cost more but it will probably be the last starter you ever need. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Starters
[Re: jeebis44]
#2310564
05/24/17 08:48 PM
05/24/17 08:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It will bolt to the transmission, but it may interfere with the exhaust pipe. IIRC they are a bit wider than the original starter.
Re: Starters
[Re: jeebis44]
#2311041
05/25/17 05:06 PM
05/25/17 05:06 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
OK - I remember there being some issue with interference but don't remember what. Is it easy to reroute the exhaust if that's the issue? I have a DB starter on the way and figured it was china junk from the price - just got it to see if the ministarter would work in my car. Any word on where to find US or Japan built minis? the fitment issue is taking off the extension for the wires. and making sure you hook up the wiring before installing the starter.
Re: Starters
[Re: mikemee1331]
#2311077
05/25/17 05:56 PM
05/25/17 05:56 PM
Supercuda
About to go away
About to go away
up yours
OK - I remember there being some issue with interference but don't remember what. Is it easy to reroute the exhaust if that's the issue? I have a DB starter on the way and figured it was china junk from the price - just got it to see if the ministarter would work in my car. Any word on where to find US or Japan built minis? the fitment issue is taking off the extension for the wires. and making sure you hook up the wiring before installing the starter. That is one of the potential fitment issues.
