Starters #2310471
05/24/17 05:36 PM
05/24/17 05:36 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Will a regular ministarter fit/work on a '66 383 in a C-body? (FuryIII automatic)
Re: Starters [Re: jeebis44] #2310560
05/24/17 08:35 PM
05/24/17 08:35 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Should fit no problem but you may need to put the main cable on first depending on what starter you get. I prefer the OEM Denso unit from Mancini. They cost more but it will probably be the last starter you ever need.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Starters [Re: jeebis44] #2310564
05/24/17 08:48 PM
05/24/17 08:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It will bolt to the transmission, but it may interfere with the exhaust pipe. IIRC they are a bit wider than the original starter.
Don't be the exception.
Re: Starters [Re: jeebis44] #2310581
05/24/17 09:14 PM
05/24/17 09:14 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
DB electrical has China made ones for $59 with free shipping. I have one on my 528, and it does a good job. They are all made in China now. You can find on eBay
Re: Starters [Re: 71birdJ68] #2310875
05/25/17 12:47 PM
05/25/17 12:47 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
OK - I remember there being some issue with interference but don't remember what. Is it easy to reroute the exhaust if that's the issue? I have a DB starter on the way and figured it was china junk from the price - just got it to see if the ministarter would work in my car. Any word on where to find US or Japan built minis?
Re: Starters [Re: jeebis44] #2310879
05/25/17 12:48 PM
05/25/17 12:48 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Seems these starters are either $60-75 or $150+
Re: Starters [Re: jeebis44] #2310901
05/25/17 01:12 PM
05/25/17 01:12 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
I am using a DB starter to crank a 604 cuin 14.5 to 1 big block. It is the small six inch version. For the $54 price, you can't beat it.
Re: Starters [Re: jeebis44] #2311041
05/25/17 05:06 PM
05/25/17 05:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the fitment issue is taking off the extension for the wires. and making sure you hook up the wiring before installing the starter.
Re: Starters [Re: mikemee1331] #2311077
05/25/17 05:56 PM
05/25/17 05:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is one of the potential fitment issues.
