Re: Bypassing the bulkhead connector/ Madd wiring
[Re: express]
#2308406
05/21/17 11:53 AM
05/21/17 11:53 AM
RapidRobert
I clean EVERY terminal/connection in the entire circuit including ground paths & I do Nachos' bulkhead parallel bypass which is to drill out the 2 main power in/out cavities in the bulkhead & replace those 4 brass terminals with a length(s) of wire straight thru & leave ~6" or so of those 2 wires rearward of the rear bulkhead half under the dash so if you need to seperate the bulkhead again in the future you can pull the front half forward to service the terminals. I like the ammeter & I add a voltmeter to switched 12V. I ain't done this but it wouldn't hurt to relay the headlights/heater/AC directly to the power source (the alt). there was some good post on fusing for protection. #1 keep the ammeter needle close to 12 0'clock
[Re: express]
#2308427
05/21/17 12:37 PM
05/21/17 12:37 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I bolt the amp gauge wires to one terminal, install headlight relays, run a large gauge wire with either an appropriate sized fusible link or a marine grade fuse from the alternator to the starter relay where the positive battery cable is also bolted.
The point is to keep any high amp load from passing through the bulkhead. If you have any high amp load accessories, use relays outside the cockpit to power them. You can leave the factory wiring at the bulkhead as is if you remove/bypass the high amp load accessories from the cockpit.
A positive distribution lug in the engine compartment comes in handy if you want to add additional loads. The only alternator I found that can support significant amp loads at idle is a GM CS144. It virtually bolts right in with a small adapter and some careful pulley shimming too. Mine puts out well over 115 amps at a low idle. It looks almost stock to most people too. Not to most people on here though.
It's easily reversible, bolt-on and leaves the stock wiring intact. It keeps things simple, and is very effective.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: express]
#2308504
05/21/17 02:02 PM
05/21/17 02:02 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
read this and you will be fine... TRUST ME!!!! my car is a driver with AC, alt upgraded and stock ammeter working correctly and SAFE. Despite all comments about the ammeter weakness and stuff, which even can be PARTIALLY true, it can work SAFELLY doing everything right. Those who say that don't trust on their own cars and how the electrical system works. http://www.dodgecharger.com/forum/index.php/topic,33574.0/all.html
