Re: Enclosed trailer question
[Re: Finoke]
#2308319
05/21/17 02:43 AM
05/21/17 02:43 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
If the trailer has a dove tail the last two to three feet it will roll out on its own on level ground with the winch line to control the speed it rolls out as long as the winch will go both ways under power ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) If the front of the trailer is a tiny higher than the back of the trailer you may need to push the car back far enough for the rear tires to reach the down slope, if the trailer has no dovetail plan on raising the tongue up high enough to have the rear of trailer lower than the front to get it to roll backwards due to gravity ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) My first three winches where one way, power in and coast out with a brake on the winch to control the out motion ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) Don't make that mistake
[Re: QuickDodge]
#2308958
05/22/17 10:42 AM
05/22/17 10:42 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Do you guys install toolboxes, a small workbench or other such things in your trailers? If so, how are these installed? Are these items easily removable?
Any other accessories / features that are useful? My trailer came with upper and lower cabinets, and the top for the lower cabinets is aluminum and makes a descent work top. I installed E-Track to the side wall, and then I ratchet strap a rolling toolbox to the wall.
[Re: Finoke]
#2309024
05/22/17 01:12 PM
05/22/17 01:12 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I have a 28' Haulmark that I pull behind my Dodge Ram 2500. I would never go smaller than that. I have a steel 6' bench on the left front wall with a tool box and vise mounted to it. I put my golf cart on the right front and still plenty of enough room for my B bodies.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
