Re: Source for quality repro Air Grabber cleaner lid wing nut.
[Re: L.R Helbling]
#2306957
05/18/17 07:49 PM
05/18/17 07:49 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
By the way as someone already stated none of the repop wing nuts are correct. If you want an original correct wing nut for your incorrect carb you gotta get one from a real original car.
(says one of the original "beat the dead horse until it is gone" posters of the infamous "wing nut" thread here on Moparts)
I still have several original 6 pak/6bbl wing nuts including a date coded restored set of carbs for a 69 1/2 4 speed car.
Give it up. You are supposed to have a Holley. Just for ghits and siggles, what is the date code and part number on your "original" carter.
i'm happy that you still have your original 6 pak/6bbl wing nuts with your vintage carbs. You must be very proud. I'd be perfectly willing to give you the date codes of the 2 Carter AVSs that I had but no longer do because they were sold off at least 15 years ago and yes, i do recognize that, had I kept them, there would not have been such an animated discussion here on Moparts dot com because the answer would be on those dates. Those carbs would have most likely would have had 70/71 dates. All it would have proved is that they were made back then for what ever Lo-Performance C Body 383 they went on. So why don't we put this thing to rest?
[Re: L.R Helbling]
#2306968
05/18/17 08:10 PM
05/18/17 08:10 PM
Posts: 4,459 Morristown Tn.
71birdJ68
Morristown Tn.
It's not on the fender tag cause the car didn't come with it.
[Re: flypaper]
#2307033
05/18/17 10:10 PM
05/18/17 10:10 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
11 pages... and no original carb...no original AG set up...and no original wing nut... OMG.... so much time I will never get back... LOL
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: JMCFAN]
#2307046
05/18/17 10:23 PM
05/18/17 10:23 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
11 pages... and no original carb...no original AG set up...and no original wing nut... OMG.... so much time I will never get back... LOL when i decided to add air grabber on to my 71 i wanted it to be all original from the intake up and i bought a 6193 holley to start whats funny is i have collected every last part execpt for the carb stud and wingnut
[Re: Mr D21]
#2307111
05/18/17 11:49 PM
05/18/17 11:49 PM
JMCFAN
New Mexico
My 70 B-Body is Holley equipped - does that help ? Mine too
[Re: Morty426]
#2307224
05/19/17 08:48 AM
05/19/17 08:48 AM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
i'm happy that you still have your original 6 pak/6bbl wing nuts with your vintage carbs. You must be very proud. I'd be perfectly willing to give you the date codes of the 2 Carter AVSs that I had but no longer do because they were sold off at least 15 years ago and yes, i do recognize that, had I kept them, there would not have been such an animated discussion here on Moparts dot com because the answer would be on those dates. Those carbs would have most likely would have had 70/71 dates. All it would have proved is that they were made back then for what ever Lo-Performance C Body 383 they went on. So why don't we put this thing to rest? Right now I'm thinking those carbs would have likely had a slightly later date. It would have proved that the carb was not original to the car. If so, I would have known that something was wrong back then. But that never happened and so this continues. But answers are starting to filter in.
[Re: NANKET]
#2307225
05/19/17 08:50 AM
05/19/17 08:50 AM
L.R Helbling
Ottawa, Ontario
Ever take a statistics class?
The possibilities of dates on those 2 carbs would have been early, right on, late, or built several years after 1971. All means nothing because they never put a 6125 AVS on a RR. But there were C-body 383 4 bbl cars built the same day your car was and the carb date would be right.
You see how it all goes full circle?
Nay nay. If built several years after, it definitely would have meant something.
[Re: flypaper]
#2307230
05/19/17 08:57 AM
05/19/17 08:57 AM
L.R Helbling
Ottawa, Ontario
11 pages... and no original carb...no original AG set up...and no original wing nut... OMG.... so much time I will never get back... LOL when i decided to add air grabber on to my 71 i wanted it to be all original from the intake up and i bought a 6193 holley to start whats funny is i have collected every last part execpt for the carb stud and wingnut I bought the car as is. Someone else added the AG. It wasn't my decision to make. Folks welcome to Facebook.
