Page 1 of 5 1 2 3 4 5
Source for quality repro Air Grabber cleaner lid wing nut. #2304333
05/14/17 02:34 PM
05/14/17 02:34 PM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
I'm looking for OE or exact repro for a 1971 383 air Grabber set up. have no idea what the wing nut looks like. What's the thread pitch for the piece of threaded rod connecting the carburetor to the cleaner lid? If it's 1/4-20, I'm looking for OE/ repro, if it's another pitch, I'll have to jury rig something because I'm using an Edlebrock 1407 carb but using the original Air Grabber baseplate so the rod has to fit through the brace that goes across the centre of the baseplate.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304355
05/14/17 03:23 PM
05/14/17 03:23 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Give Frank Baldason a call, he has the most accurate stuff around. I think whatever you find it will fit the Edlebrock, even though a Holley was used from the factory.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304421
05/14/17 05:39 PM
05/14/17 05:39 PM
Ottawa, Ontario
Ottawa, Ontario
Who's Frank Baldason and how do I reach him? Actually carter AVS was used from the factory but I get your meaning.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304440
05/14/17 06:27 PM
05/14/17 06:27 PM
MA
steve70 Offline
steve70  Offline
MA
http://www.rogergibsonautorestoration.com/Frank/Frank-Badalson-Home/
I thought the 383 cars used a Holley and the 440 cars used a Carter?
1970 Challenger T/A 4 speed
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304457
05/14/17 07:05 PM
05/14/17 07:05 PM
Ottawa, Ontario
Ottawa, Ontario
Steve, thanks for the link. I left a message on his website. 1971 Roadrunners all used various Carter carbs except for the 440 + 6. That one used 3 different 2 bbl Holley carbs. The original factory carb on my car was the Carter AVS 6125S. Thanks
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304472
05/14/17 07:27 PM
05/14/17 07:27 PM
Ottawa, Ontario
Ottawa, Ontario
...and, I also should include Holley R-6193A and R-4735a were both used on 383 Roadrunners with "fresh Air Intake" systems. I guess that means the Air Grabber hood option.
and Holley R-6191A and R-4668A were both used on 383 Roadrunners with "heated air intake" systems. Not sure what that means unless they are talking about a hot air stove before the air cleaner.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304476
05/14/17 07:34 PM
05/14/17 07:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I would call Frank tomorrow, he's really busy, so I don't know how a call back would work.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: 71birdJ68] #2304594
05/14/17 11:15 PM
05/14/17 11:15 PM
WV
Little Detroit Offline
WV
www.littledetroitrestorations.com has them in stock check out website.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: Little Detroit] #2304613
05/14/17 11:54 PM
05/14/17 11:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
ALL 1971 383 Road Runners had HOLLEY carbs when new!
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: 6bblgt] #2304744
05/15/17 09:25 AM
05/15/17 09:25 AM
Ottawa, Ontario
Ottawa, Ontario
Not according to the factory service manual.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304776
05/15/17 11:11 AM
05/15/17 11:11 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The wing nuts can be purchased directly from AMK Products out of Winchester, VA. This is the place that provides the hardware to many of the vendors. They do have a $30 minimum order, but it does not take much to put together an order as they have so many pieces once you start to looking at their inventory.
If you are really wanting 100% correct wing nuts, you will need to find originals. The reproductions are close and most people do not know what to look for, but the originals do not have the radius that the reproductions have.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304795
05/15/17 11:40 AM
05/15/17 11:40 AM
Ottawa, Ontario
Ottawa, Ontario
Understood. I've contacted a couple of vendors and they give the impression that they're too busy to talk which is good for them but not so good for me. I'm going to see if I can source the part locally from auto restoration garages that I'm familiar with around here. Most of the vendors on Ebay want an average of $36 US for shipping so it's not cost effective for me right now especially considering that we are talking about a $2.50 part. Also, I'm not really looking for anything to combine on an order. Thanks for your info. If I can't find a good looking wing nut, I'll defer the problem till later.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2304984
05/15/17 05:26 PM
05/15/17 05:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Beware that the Service manual doesn't tell you what came with what. Your broadcast sheet does. Do you have one?
It is HIGHLY UNLIKELY that your car came with a Carter.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: Morty426] #2305068
05/15/17 07:35 PM
05/15/17 07:35 PM
Ottawa, Ontario
Ottawa, Ontario
No broadcast sheet was ever found with my car. The FSM does indicate what engines that came with what transmission was married up to a specific carb. All you have to know is what engine/tranny combo were available with your particular year/make/model and you will know what carburetor belongs on the car for a specific combo. That is on your fender tag. Broadcast sheets are nice to have but you don't need them to find that out. Various sources on the web suggest that 1971 Roadrunners had more Carters in them than Holleys and the exceptions to that rule I've already mentioned in this thread. My car originally came with a Carter AVS because it came standard with a 383 and 727 auto trans. The FSM backs that up. The Air Grabber hood though, is a completely different story.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2305210
05/15/17 10:52 PM
05/15/17 10:52 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
People with a lot of knowledge and experience decoding these cars are trying to help you here. The typical number you see coded on the broadcast sheet for a 383 4bbl auto 71 runner without an air grabber is 30. This translates to a Holley carb part number R4668. Typical sheet number for a 383 4bbl auto with air grabber is 42, also a Holley carb.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: Butterscotch71] #2305224
05/15/17 11:14 PM
05/15/17 11:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
all 1971 E & B-body 383 4bbl engines are orange painted 383HP & they all came with HOLLEY carbs
regardless of what you are comprehending from the service manual & your worrying about the correct $2.50 wingnut? realcrazy
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2305372
05/16/17 09:12 AM
05/16/17 09:12 AM
Ottawa, Ontario
Ottawa, Ontario
Can't help you, chum if you don't believe what I'm telling you. Holley R4668 carbs were put on Roadrunners with heated air intakes like I mentioned in a previous post. Mine never came with that option so I got the Carter AVS. Typical numbers found on broadcast sheets are fine for statistical purposes but they do not describe the rules for putting which carb on which car. FSM does.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2305407
05/16/17 11:00 AM
05/16/17 11:00 AM
WV
WV
according to the famous little white book written by the original "GURU" to whom you all worship the gentleman seems to be correct about his carburetor #6125 and its listed in the 1971 parts manual. huh? fancy that.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: Little Detroit] #2305415
05/16/17 11:12 AM
05/16/17 11:12 AM
WV
WV
FOR THE RECORD; the broadcast sheet is information about the particular car or "VIN", not "all " 1971's. however the parts manual lists parts that were available with the motor body style it was optioned or coded for.
Re: Source for quality repro Air Grabber cleaner lid wing nut. [Re: L.R Helbling] #2305485
05/16/17 02:10 PM
05/16/17 02:10 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
OK let's see if this makes sense to you.
The FSM is a service manual. It's where you go to find out how to repair something or what the specs or settings are for something. It does not tell you what goes on what. For that they have a Parts Manual.
If you go to the parts manual. It's section 14-30-0. It shows that the Carter is only used on C Bodies. So yes there is a 383 AT Carter in 71 but it was never used in your application. It was used in the 330HP C body application.
Attached PDF document
71 Carbs.pdf (88 downloads)
