Can you remove a small stain from black Organosol paint ? #2238035
01/20/17 06:38 PM
01/20/17 06:38 PM
69x Offline OP
69x  Offline OP
IS there something to use on this that will help clean up a small stain ? not sure what caused the stain, thanks.
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2238353
01/21/17 12:32 PM
01/21/17 12:32 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I had a small stain( Not Sure What It Was) on the fender about the size of eraser on a pencil, I tried some Turtle Wax Liquid Ice a couple of times Rubbed Very Lightly) and made it better but did not get rid of it
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2238377
01/21/17 01:23 PM
01/21/17 01:23 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Picture please. What ever you end up doing, if you rub it too hard it will burnish the spot making it look altered too.
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2238413
01/21/17 02:15 PM
01/21/17 02:15 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
Never tried it but might be worth a look
http://www.ratwax.net/
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2238602
01/21/17 08:01 PM
01/21/17 08:01 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
I just had my hood painted in Organosol so I'll be watching this topic for helpful responses. Thanks. Lou
Re: Can you remove a small stain from black Organosol paint ? [Re: jbc426] #2238614
01/21/17 08:33 PM
01/21/17 08:33 PM
69x Offline OP
69x  Offline OP
I cannot get to the car right now, I know this paint is touchy, the spot is small, dime size, very thin light grey, but you can see through to the black paint.
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2239087
01/22/17 04:15 PM
01/22/17 04:15 PM
pa.
dan9 Offline
dan9  Offline
pa.
It think it will be tough to do. If you rub too hard you will make it shiney, then you will look at that spot every time you get near the car.
Re: Can you remove a small stain from black Organosol paint ? [Re: dan9] #2239453
01/22/17 11:19 PM
01/22/17 11:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Maybe dampen a q-tip with wax and grease remover and lightly wet the area just to see what it does?
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2239820
01/23/17 03:18 PM
01/23/17 03:18 PM
Chicago
PurpleBeeper Offline
Chicago
Yeah, organisol (vinyl paint) is not very "tough". Make SURE whatever cleaner you use it doesn't contain any chemical in it that ends in "one" (ketones, like acetone) since those will completely dissolve organisol paint pretty quick. Toluene/xylene/glycol ethers are pretty tough on organisols too. You might be stuck with hot soap & water....."maybe" some type of alcohol (isopropanol, ethanol) but be careful with those too and "test in an inconspicuous area first" just to be sure.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2239842
01/23/17 03:59 PM
01/23/17 03:59 PM
Ottawa, Ontario
Ottawa, Ontario
If it were me, I'd try car wash in water with a bristle brush but selecting what kind of rigidity to use would be a problem. I'd use the softest bristles first and work my way to stiffer until I got some noticeable results. Just an idea I had but it isn't proven from my part yet.
Re: Can you remove a small stain from black Organosol paint ? [Re: 69x] #2239886
01/23/17 05:31 PM
01/23/17 05:31 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
Why rub on the paint at all? Let the cleaner/chemical loosen it. As mentioned try your solvents and soaps in a hidden area first to make sure it will not melt the paint. You have a textured paint and rubbing it will change the texture.
Do you have any idea what this stain is? Petroleum or organic based? Tree sap, bug juice, food, paint, oil/grease?
Try cooking oil & peanut butter they can loosen things and make them slide off. They will leave a residue and feed the paint and make it look different. A bit of simple green Will remove that.
Some brake clean removes paint, others do not. Experiment with that if needed.
Bristle brush is not much different than sandpaper.
Re: Can you remove a small stain from black Organosol paint ? [Re: L.R Helbling] #2306102
05/17/17 02:37 PM
05/17/17 02:37 PM
69x Offline OP
69x  Offline OP
Well I found something that works.
Wizards 01220 Wipe Down Matte Paint Detailer
I was very happy with the results
