Ram 2500 pinion seal blew. Question #2304069
05/13/17 11:07 PM
05/13/17 11:07 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
My 2000 Ram 2500 Cummins 2wd blew out the pinion seal. Not sure if that's normal for a 200,000 mile truck. It wasn't howling when I got home. Maybe I'm lucky and didn't burn up anything. Are these rears shimmed? As in don't worry about a crush sleeve? Thanks.
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304127
05/14/17 12:28 AM
05/14/17 12:28 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
mark the nut and the pinion with a center punch , then replace the seal and retighten it to the same spot , done !
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304144
05/14/17 01:30 AM
05/14/17 01:30 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Thanks.
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304242
05/14/17 11:41 AM
05/14/17 11:41 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had blown the seal in my 96 2500 V10 truck at 85K miles, you did good! penguin
JB Rhinehart, Realist
A-Body's RULE!
Re: Ram 2500 pinion seal blew. Question [Re: calrobb2000] #2304272
05/14/17 12:53 PM
05/14/17 12:53 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
This is exactly what I did on my 1500. No issues so far, 50k later. It was starting to leave puddles in the driveway.
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304279
05/14/17 01:05 PM
05/14/17 01:05 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would be careful, I suspect that the later Danas may use a crush sleeve
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304344
05/14/17 03:12 PM
05/14/17 03:12 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
My 2001 2500 was blown when I got the truck @131k. No crush sleeve. How to video in the link below.
https://mopar1973man.com/topic/2016-diy-...p;comment=18206
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304737
05/15/17 09:12 AM
05/15/17 09:12 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Check the vent.
Re: Ram 2500 pinion seal blew. Question [Re: da50r] #2304774
05/15/17 11:06 AM
05/15/17 11:06 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Why do 1994+ Rams have more than average pinion seal, pre-load, and pinion bearing problems?
Did prior years use another seal supplier, perhaps from a USA based supplier?
Is the internal diameter fit of the seal off spec or out of round, or the external surface on which the seal rubs off spec, rough, too soft?
Is a change of lube chemistry attacking the lip material?
On the 9.25 i have long suspected the crush sleeve keeps slowly shortening and ruining the preload, which ruins the pinion bearings, which creates the slop that ruins the seal.
But Dana problems indicate there may be a Ram design common flaw affecting both diffs ?
