Re: Ram 2500 pinion seal blew. Question
[Re: da50r]
#2304144
05/14/17 01:30 AM
05/14/17 01:30 AM
Posts: 2,628 Middle TN
da50r
Middle TN
[Re: calrobb2000]
#2304272
05/14/17 12:53 PM
05/14/17 12:53 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
mark the nut and the pinion with a center punch , then replace the seal and retighten it to the same spot , done ! This is exactly what I did on my 1500. No issues so far, 50k later. It was starting to leave puddles in the driveway.
[Re: da50r]
#2304279
05/14/17 01:05 PM
05/14/17 01:05 PM
Posts: 5,163 CT
GTX MATT
CT
I would be careful, I suspect that the later Danas may use a crush sleeve
[Re: da50r]
#2304344
05/14/17 03:12 PM
05/14/17 03:12 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
My 2001 2500 was blown when I got the truck @131k. No crush sleeve. How to video in the link below. https://mopar1973man.com/topic/2016-diy-...p;comment=18206
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: da50r]
#2304774
05/15/17 11:06 AM
05/15/17 11:06 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Why do 1994+ Rams have more than average pinion seal, pre-load, and pinion bearing problems?
Did prior years use another seal supplier, perhaps from a USA based supplier?
Is the internal diameter fit of the seal off spec or out of round, or the external surface on which the seal rubs off spec, rough, too soft?
Is a change of lube chemistry attacking the lip material?
On the 9.25 i have long suspected the crush sleeve keeps slowly shortening and ruining the preload, which ruins the pinion bearings, which creates the slop that ruins the seal.
But Dana problems indicate there may be a Ram design common flaw affecting both diffs ?
