Re: 10" Drum Brake Identification
[Re: preddy]
#2301165
05/08/17 02:10 PM
05/08/17 02:10 PM
RapidRobert
the shoe width might likely help pin it down (year/model) & I would measure across the horizontle e brake lever distance & have that dimention in hand so if someone has some pieces in hand but likely someone will pin this down to a group of years/models.
[Re: preddy]
#2301180
05/08/17 02:36 PM
05/08/17 02:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Depends, basically there are two 10" drum setups. The early A body that had the 4" bolt pattern and then everything else. I believe the early A body shoes are less than 2" wide, so if you have those you are dealing with the harder to find setup.
Assuming the PO didn't reuse the 68 A body backing plate and redrilled the drums you should be able to use the everything else 10" drum setup.
[Re: preddy]
#2301186
05/08/17 02:42 PM
05/08/17 02:42 PM
RapidRobert
I'm thinking it is the common any year BBP 10" drum assy.
[Re: buildanother]
#2302024
05/09/17 10:20 PM
05/09/17 10:20 PM
Supercuda
About to go away
About to go away
up yours
That's a nasty road runner by the way..... ? RR?
[Re: buildanother]
#2302164
05/10/17 01:51 AM
05/10/17 01:51 AM
Posts: 701 Southern Maryland
preddy
Southern Maryland
That's a nasty road runner by the way..... Thank you. I'm trying to build a nastier cuda Same engine and about 600 lbs lighter.
