Page 3 of 3 1 2 3
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299474
05/05/17 12:11 PM
05/05/17 12:11 PM
an8sec70cuda Offline
I've been using the VR1 conventional.
I used to run Mobil One 15w50 synthetic, but it got to be VERY hard to find. The conventional VR1 I can get at any parts store around here. The synthetic VR1 isn't as readily available and in only one or two viscosities.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299487
05/05/17 12:37 PM
05/05/17 12:37 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've been running Lucas HotRod 10/30 for years in my solid flat tappet engine. I run 10/30 because my bearing clearances are more typical of a street engine than a race motor. I typically change it once a year, in the winter when I also do a valve adjustment. Important to note that my car sees well less than 1000 miles a year. So far so good.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299518
05/05/17 01:32 PM
05/05/17 01:32 PM
jersey
Spaceman Spiff Offline
jersey
As recommended by my engine builder (HPMIKE on this site). 20w50 vr1.
July will be 2 years it's together. I drive it all over, probably has close to 5,000 miles on it.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299566
05/05/17 02:52 PM
05/05/17 02:52 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Another vote for the Valvoline 10W-30 VR-1. I can find at Napa for $6.99 a quart.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299647
05/05/17 06:01 PM
05/05/17 06:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Ask machinists that are drag racers what they use. Joe Gibbs, Lucas, royal purple.
Always like Valvoline oil also, nice to have options.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299649
05/05/17 06:20 PM
05/05/17 06:20 PM
With the results I've seen from using "normal" oils like Mobil One and Valvoline VR1, I've seen no reason to spend the extra money on oils like Joe Gibbs, etc.
If your oiling system is up to the task of what your engine needs, any good quality oil will work. Just my 2 cents.
CHIP
Re: Which Motor Oil Do I Use After Break In? [Re: an8sec70cuda] #2299652
05/05/17 06:25 PM
05/05/17 06:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
iagree 10000000000%
Re: Which Motor Oil Do I Use After Break In? [Re: an8sec70cuda] #2299732
05/05/17 08:55 PM
05/05/17 08:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same hear as I run the VR1 conventional non synthetic and I just bought 7 qts the other day for $5.99 per Qt and Salvo's. Ron
Re: Which Motor Oil Do I Use After Break In? [Re: 383man] #2299753
05/05/17 09:36 PM
05/05/17 09:36 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I use Brad Penn 20w-50, usually get for $60 a case. $5 quart
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299930
05/06/17 08:08 AM
05/06/17 08:08 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Mobil 1 Synthetic. 5 quart container at Wally World or Amazon for about 25 bucks. Have used for many years....Multi years between oil changes for almost no annual mileage cars.
Run in engines with both flat tappet and roller cams Zero oil issues.
If GM says good enough enough for ZR 1 and Z 06 Corvettes and Porsche or Benz say good enough for them,,,who am I to argue with engineers that are far more knowledgeable and have far more on the line than I.
Just as asking the best beer, religion, political persuasion or perhaps hair coloring one might favor in a woman.
Uh, oh! When does the ground war begin?
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2299950
05/06/17 09:34 AM
05/06/17 09:34 AM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
Brad Penn
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2300008
05/06/17 11:44 AM
05/06/17 11:44 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Conventional for me...Joe
Page 3 of 3 1 2 3
