Which Motor Oil Do I Use After Break In?
#2298041
05/03/17 12:50 AM
05/03/17 12:50 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I'm about to start my engine for the first time. What type and weight motor oil is best to use once it is past the 20 minute break in? Here are my engine specs.
440ci Bored .40 over Closed chambered heads ported and polished 2.14/1.81 valves, hardened seats Harland Sharp roller rockers Comp Cam XE 274 cam and lifters LY rods Keith Black Hyperutectic pistons Forged crank Clevite bearings Factory mains ARP head, main and rod bolts Double roller timing chain Edelbrock RPM intake Holley Street Avenger 770 vacuum secondary TTi 1 7/8" headers 2.5" mandrel bent exhaust to stock tips Turbo mufflers H pipe mini starter
Thanks!
I’m listening.
Re: Which Motor Oil Do I Use After Break In?
[Re: Big Bad Bee]
#2298102
05/03/17 02:36 AM
05/03/17 02:36 AM
Posts: 1,505 TN
SCATPACK 1
TN
Valvoline Racing Oil is what I have always used. Never lost a cam or lifters with it. Any time I used something different, I lost a cam and lifters on a new Comp Cam that WAS broken in correctly. Valvoline Racing Oil still has the max amount of the Zinc additive you can get without a custom blend. As long as you are not running Catalytic converters, you should not have any issues with it. http://www.valvoline.com/products/VR...otor%20Oil.pdfThe Valvoline VR-1 Racing Motor Oil • The #1 selling Racing Oil of all time and race track proven. • Protects against high-temperature deposits for a cleaner engine. • ZDDP additive provides tough anti-wear protection. • Enhanced with fricition modifier to improve horsepower. • Formulated with enhanced anti-foam system. Approvals/Performance Levels Viscosity Grade/Other API SM/SL/SJ - - - - - - 20W-50 API SH 10W-30 20W-50 API CD 10W-30 20W-50 Test 10W-30 20W-50 Vis @ 100°C (cSt) 11.5 20.5 Vis @ 40°C (cSt) 77.0 181.8 Viscosity Index 143 132 Spec Gravity @ 60°F 0.8722 0.888 Density (lbs/gal) 7.27 7.39 Total Base No. 8 8 Flash COC (°C) 212 248 Pour Point (°C) -33 -24 CCS cP (°C) 6200(-25C) 8000(-15C) MRV TP-1 cP (°C) 20,000(-30C) 27,000(-20C) Noack % off @ 250C <15 <15 Sulfated Ash 1 1 Zinc/Phosphorus 0.130/0.120 0.130/0.120 Calcium 0.250 0.250
Old Geezer Racing
[Re: SCATPACK 1]
#2298108
05/03/17 02:44 AM
05/03/17 02:44 AM
Thumperdart
State of confusion
Same here on Valvoline but there are a few other great oils out there........I know my tear-downs are an average of 6-7 years it seems and things look real good considering how much I drive my car especially testing several different carbs. Valvoline and Isky cams...........Innovators not copy cats.......
[Re: Blown_Hemi]
#2298157
05/03/17 09:42 AM
05/03/17 09:42 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Valvoline VR1 in the gray bottle is what I run. I do oil samples and it always runs around 1200PPM of Zinc. Brab Penn, Joe Gibbs and Amsoil make some good oils also that probably have a higher rating of zinc. Valvoline is easy to find here and $7 a QT.
The only Carbs I care about are under the hood!
[Re: Big Bad Bee]
#2298164
05/03/17 10:09 AM
05/03/17 10:09 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
Valvoline is good, but I like Brad Penn oils a little more. This old thread may interest you.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: Big Bad Bee]
#2298218
05/03/17 12:09 PM
05/03/17 12:09 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Valvoline VR1 race oil...found at any parts store.
[Re: Challenger 1]
#2298244
05/03/17 12:47 PM
05/03/17 12:47 PM
Thumperdart
State of confusion
I'd leave the breakin oil in for 5000 miles...why waste it? It is what I do have done for 30 years.. Some folks waste so much oil it's You're kidding right............
[Re: Thumperdart]
#2298261
05/03/17 01:21 PM
05/03/17 01:21 PM
Big Bad Bee
Spokane Valley, WA
Excellent information, although wouldn't using the break in oil wear your motor down to nothing if you kept using it? Does the Valvoline VR-1 come in just one viscosity?
I’m listening.
[Re: Big Bad Bee]
#2298267
05/03/17 01:26 PM
05/03/17 01:26 PM
an8sec70cuda
Excellent information, although wouldn't using the break in oil wear your motor down to nothing if you kept using it? Does the Valvoline VR-1 come in just one viscosity? No, it comes in several different viscosities. I'd use 10w30 or maybe 20w50 if the clearances are on the loose side.
[Re: Challenger 1]
#2298277
05/03/17 01:51 PM
05/03/17 01:51 PM
Posts: 287 PA
Harry's Taxi 2
PA
I'd leave the breakin oil in for 5000 miles...why waste it? It is what I do have done for 30 years.. Some folks waste so much oil it's For 30 years huh? What "break-in" oil were you using 30 years ago?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Big Bad Bee]
#2298282
05/03/17 02:06 PM
05/03/17 02:06 PM
Posts: 5,894 Florida
Locomotion
I'd break it in for longer than 20 minutes. I like to go through several heat cycles in my race engines before putting the "regular" oil in afterwards, which is Amsoil Dominator. Running softer valve springs for break in is good insurance, but a pain because then you have to change them out to what's recommended. Amsoil Tech Bulliten - High zinc oils.
[Re: Harry's Taxi 2]
#2298358
05/03/17 04:06 PM
05/03/17 04:06 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
I'd leave the breakin oil in for 5000 miles...why waste it? It is what I do have done for 30 years.. Some folks waste so much oil it's For 30 years huh? What "break-in" oil were you using 30 years ago? Why would you run any oil for 5000 miles, especially on a new engine? Oil is cheap, engine parts are not.
[Re: Leigh]
#2298395
05/03/17 05:02 PM
05/03/17 05:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On a flat tappet can you keep pouring in the additive on every oil change.. whats it gonna hurt if you wait on the first oil change.. I still have the break in additive in my engine but its only been 400 miles
