Page 1 of 3 1 2 3
Which Motor Oil Do I Use After Break In? #2298041
05/03/17 12:50 AM
05/03/17 12:50 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I'm about to start my engine for the first time. What type and weight motor oil is best to use once it is past the 20 minute break in? Here are my engine specs.
440ci
Bored .40 over
Closed chambered heads ported and polished
2.14/1.81 valves, hardened seats
Harland Sharp roller rockers
Comp Cam XE 274 cam and lifters
LY rods
Keith Black Hyperutectic pistons
Forged crank
Clevite bearings
Factory mains
ARP head, main and rod bolts
Double roller timing chain
Edelbrock RPM intake
Holley Street Avenger 770 vacuum secondary
TTi 1 7/8" headers
2.5" mandrel bent exhaust to stock tips
Turbo mufflers
H pipe
mini starter
Thanks!
I’m listening.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298048
05/03/17 01:01 AM
05/03/17 01:01 AM
Kirkland, Washington
Pacnorthcuda Offline
A 10w30 that is appropriate for flat tappets--(high ZDDP)
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298057
05/03/17 01:10 AM
05/03/17 01:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Im breaking in with flat tappet on amsoil 30w break in. 10/40 or 15/40 after that. Amsoil hotrod.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298102
05/03/17 02:36 AM
05/03/17 02:36 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Valvoline Racing Oil is what I have always used. Never lost a cam or lifters with it. Any time I used something different, I lost a cam and lifters on a new Comp Cam that WAS broken in correctly. Valvoline Racing Oil still has the max amount of the Zinc additive you can get without a custom blend. As long as you are not running Catalytic converters, you should not have any issues with it.
http://www.valvoline.com/products/VR...otor%20Oil.pdf
The Valvoline VR-1 Racing Motor Oil
• The #1 selling Racing Oil of all time and race track proven.
• Protects against high-temperature deposits for a cleaner engine.
• ZDDP additive provides tough anti-wear protection.
• Enhanced with fricition modifier to improve horsepower.
• Formulated with enhanced anti-foam system.
Approvals/Performance Levels
Viscosity Grade/Other
API SM/SL/SJ
- - - - - - 20W-50
API SH
10W-30 20W-50
API CD
10W-30 20W-50
Test
10W-30
20W-50
Vis @ 100°C (cSt)
11.5
20.5
Vis @ 40°C (cSt)
77.0
181.8
Viscosity Index
143
132
Spec Gravity @ 60°F
0.8722
0.888
Density (lbs/gal)
7.27
7.39
Total Base No.
8
8
Flash COC (°C)
212
248
Pour Point (°C)
-33
-24
CCS cP (°C)
6200(-25C)
8000(-15C)
MRV TP-1 cP (°C)
20,000(-30C)
27,000(-20C)
Noack % off @ 250C
<15
<15
Sulfated Ash
Zinc/Phosphorus
0.130/0.120
0.130/0.120
Calcium
0.250
0.250
Old Geezer Racing
Re: Which Motor Oil Do I Use After Break In? [Re: SCATPACK 1] #2298108
05/03/17 02:44 AM
05/03/17 02:44 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here on Valvoline but there are a few other great oils out there........I know my tear-downs are an average of 6-7 years it seems and things look real good considering how much I drive my car especially testing several different carbs. Valvoline and Isky cams...........Innovators not copy cats....... thumbs
Re: Which Motor Oil Do I Use After Break In? [Re: SCATPACK 1] #2298111
05/03/17 02:51 AM
05/03/17 02:51 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Would that valvoline be in the gray or the black bottle?
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298153
05/03/17 09:10 AM
05/03/17 09:10 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Brad Penn oil.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Which Motor Oil Do I Use After Break In? [Re: Blown_Hemi] #2298157
05/03/17 09:42 AM
05/03/17 09:42 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Valvoline VR1 in the gray bottle is what I run. I do oil samples and it always runs around 1200PPM of Zinc. Brab Penn, Joe Gibbs and Amsoil make some good oils also that probably have a higher rating of zinc. Valvoline is easy to find here and $7 a QT.
The only Carbs I care about are under the hood!
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298164
05/03/17 10:09 AM
05/03/17 10:09 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
Valvoline is good, but I like Brad Penn oils a little more. This old thread may interest you.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298167
05/03/17 10:16 AM
05/03/17 10:16 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd leave the breakin oil in for 5000 miles...why waste it? It is what I do have done for 30 years..
Some folks waste so much oil it's realcrazy
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298218
05/03/17 12:09 PM
05/03/17 12:09 PM
an8sec70cuda Offline
Valvoline VR1 race oil...found at any parts store.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Motor Oil Do I Use After Break In? [Re: Challenger 1] #2298244
05/03/17 12:47 PM
05/03/17 12:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You're kidding right............ laugh2
Re: Which Motor Oil Do I Use After Break In? [Re: Thumperdart] #2298261
05/03/17 01:21 PM
05/03/17 01:21 PM
Spokane Valley, WA
Spokane Valley, WA
Excellent information, although wouldn't using the break in oil wear your motor down to nothing if you kept using it? confused
Does the Valvoline VR-1 come in just one viscosity?
I’m listening.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298267
05/03/17 01:26 PM
05/03/17 01:26 PM
No, it comes in several different viscosities. I'd use 10w30 or maybe 20w50 if the clearances are on the loose side.
CHIP
Re: Which Motor Oil Do I Use After Break In? [Re: Challenger 1] #2298277
05/03/17 01:51 PM
05/03/17 01:51 PM
PA
Harry's Taxi 2 Offline
PA
For 30 years huh? What "break-in" oil were you using 30 years ago?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298282
05/03/17 02:06 PM
05/03/17 02:06 PM
Locomotion Offline
Locomotion  Offline
I'd break it in for longer than 20 minutes. I like to go through several heat cycles in my race engines before putting the "regular" oil in afterwards, which is Amsoil Dominator.
Running softer valve springs for break in is good insurance, but a pain because then you have to change them out to what's recommended.
Amsoil Tech Bulliten - High zinc oils.
Re: Which Motor Oil Do I Use After Break In? [Re: Harry's Taxi 2] #2298358
05/03/17 04:06 PM
05/03/17 04:06 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Why would you run any oil for 5000 miles, especially on a new engine? Oil is cheap, engine parts are not.
Re: Which Motor Oil Do I Use After Break In? [Re: Big Bad Bee] #2298374
05/03/17 04:29 PM
05/03/17 04:29 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I blend mine my self out of 10W30 Royal Purpel mineral break in oil and 20W50 mineral 76 Unocal in a 50/50 blend and it works for me and my 505 CI.
Re: Which Motor Oil Do I Use After Break In? [Re: NANKET] #2298383
05/03/17 04:46 PM
05/03/17 04:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Tesar recommends Klotz 10/40 for my heap.
Re: Which Motor Oil Do I Use After Break In? [Re: Leigh] #2298395
05/03/17 05:02 PM
05/03/17 05:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a flat tappet can you keep pouring in the
additive on every oil change.. whats it gonna
hurt if you wait on the first oil change.. I
still have the break in additive in my engine
but its only been 400 miles
wave
Page 1 of 3 1 2 3
