Detroit area tune-up #2293432
04/24/17 08:57 PM
04/24/17 08:57 PM
Whitey Nocar Offline OP
looking for someone to bring the Coronet to tune it. she's running a little rough. idles nicely, but when accelerating she stumbles. Looking for someone locally that knows Mopar 318s. don't mind spending a few bucks to get it tuned properly, just don't want to get ripped off. Any local members have a trustworthy shop or have any suggestions? thanks in advance.
Detroit area tune up. [Re: Whitey Nocar] #2299209
05/04/17 10:27 PM
05/04/17 10:27 PM
Maybe should have titles this Detroit area instead of Livingston county?
Re: Detroit area tune-up [Re: Whitey Nocar] #2299244
05/04/17 11:22 PM
05/04/17 11:22 PM
Likely the guys here can pinpoint it (or pin it down to several potentials). what year what carb what mods (if any) any changes/recent changes/mods. stumble at part or WOT?
Re: Detroit area tune-up [Re: Whitey Nocar] #2299337
05/05/17 02:11 AM
05/05/17 02:11 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Sounds like cuberator problems to me! Back in the late 70's, I had a '73 318 Roadrunner & the factory carb was a real gas hog. I installed a new Holley Economaster & it was smoother & a few MPG better. Economasters are probably a thing of the past now...
Re: Detroit area tune-up [Re: Whitey Nocar] #2299436
05/05/17 11:21 AM
05/05/17 11:21 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
http://www.jakesautomotive.com/
I've always heard good things about these guys.
Dennis
Re: Detroit area tune-up [Re: Whitey Nocar] #2300964
05/08/17 12:34 AM
05/08/17 12:34 AM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
Is there a deptula performance out in Howell? They used to be in town and always had old mopars in the shop.. Heard the moved out that way when rent went up.
71 gtx.....
Re: Detroit area tune-up [Re: sleddinfool] #2301030
05/08/17 07:54 AM
05/08/17 07:54 AM
6T4 Polara Offline
6T4 Polara  Offline
Re: Detroit area tune-up [Re: cudaboy] #2301193
05/08/17 03:02 PM
05/08/17 03:02 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Dennis
Those guys chassis dyno'd my Dad's 408 motor. Did a nice job of dialing it in.
Re: Detroit area tune-up [Re: RapidRobert] #2301364
05/08/17 09:34 PM
05/08/17 09:34 PM
Original 318 with Holly650, has headers buts that's about it. No changes, nothing new except the missing... almost seems like on aceleration it cuts in and out. Idols fine, just under moderate to hard acceleration
Vacuum leak or timing maybe?
Re: Detroit area tune-up [Re: Whitey Nocar] #2301419
05/08/17 11:00 PM
05/08/17 11:00 PM
plugs/plug wires/rotor phasing might be potentials. any possibility the carb might be jetted lean? 15 or a bit more might be a good initial & 35 is a reasonably close SB total (initial+slots). what year 318? bone stock ex for headers & the carb & what model carb?
Re: Detroit area tune-up [Re: Whitey Nocar] #2301669
05/09/17 12:10 PM
05/09/17 12:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'd normally offer to help and could most likely take care of it for you, but I'm not at all set up to accept other folks' vehicles into my shop and have to do it on a "just helping out a friend" basis instead of it being on a professional level. It's all I can do to handle my own projects and sometimes that is too much LOL.
If you have money to spend, I'd say try Jakes. Joy Fair Autocraft in Pontiac was a good shop for this kind of work years ago, but I don't know if they are still open or if they've maintained a decent reputation. Vinsetta Garage was good, until it became a restaurant.
Rich H.
Esse Quam Videri
Re: Detroit area tune-up [Re: Whitey Nocar] #2301782
05/09/17 03:21 PM
05/09/17 03:21 PM
crlush Offline
crlush  Offline
Where do you live?
Re: Detroit area tune-up [Re: crlush] #2301979
05/09/17 08:58 PM
05/09/17 08:58 PM
Howell
Re: Detroit area tune-up [Re: ZIPPY] #2301983
05/09/17 09:11 PM
05/09/17 09:11 PM
Shoot, we may already be friends... or acquaintances, this SE MI Mopar community seems to cross paths every now and then.
Re: Detroit area tune-up [Re: Whitey Nocar] #2302416
05/10/17 02:57 PM
05/10/17 02:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yeah, pretty good chance of it, actually.
I've known Doug and Randy/RIP (in your friends list)for quite a few years.
Rich H.
Esse Quam Videri
Re: Detroit area tune-up [Re: Whitey Nocar] #2316019
06/04/17 04:30 PM
06/04/17 04:30 PM
Update... in case anyone cares. A good tune up solved the issue. I had a couple fried ignition wires. New plugs, wires, rotor, cap, points, condenser, timing was adjusted, carb adjusted.
Paid $290. Which I thought was steep for a tune up, but I haven't paid for a tune up since the 80's, and the car purrs, so I'm happy.
Re: Detroit area tune-up [Re: Whitey Nocar] #2316213
06/04/17 09:28 PM
06/04/17 09:28 PM
I would agree a bit steep but if you're happy I'm happy.
Re: Detroit area tune-up [Re: Whitey Nocar] #2316459
06/05/17 09:04 AM
06/05/17 09:04 AM
crlush Offline
crlush  Offline
Where did you end up going?
Re: Detroit area tune-up [Re: crlush] #2317007
06/06/17 03:05 AM
06/06/17 03:05 AM
Meyer's Automotive in Howell.
Re: Detroit area tune-up [Re: Whitey Nocar] #2317105
06/06/17 12:36 PM
06/06/17 12:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good deal smile
Rich H.
Esse Quam Videri
