CRT 500 518 618 trans brake reverse manual VB TESTED #2292961
04/23/17 11:02 PM
04/23/17 11:02 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Worked good. Going on the market soon
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293176
04/24/17 12:21 PM
04/24/17 12:21 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Very cool John thanks for the update. What would it take to make one with out transbrake?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: mopar65] #2293188
04/24/17 01:00 PM
04/24/17 01:00 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
the way I wanted to design my 518-618 valve body is to have no electronics, no shift solenoids for the shifting, I wanted 1 2 3 4 to be all off the manual valve, this way, there is no issues with delayed shifted with electronics, and no way a solenoid to go bad for shifting wile racing. To do this, I had to put Reverse and Neutral on the same detente, so my shift pattern is :
P
N-R (reverse when apply trans brake or reverse solenoid)
3
1st 2nd 3rd 4th are all off the manual valve, this makes for the best
flow and apply pressure. This can only be done when using N&R on the same detente. So you dont want a trans brake, I can set the valve body up so the solenoid only works in reverse, but we all know, if you have a valve body with a trans brake, you going to want to play with it and try it, they are a lot of fun at stop lights
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293190
04/24/17 01:03 PM
04/24/17 01:03 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
CRT test truck, Thanks to Chris Baxter
17990980_10211052338617645_2944142300527416285_n.jpg18057644_10211052338977654_3320012790930130625_n.jpg
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293207
04/24/17 01:37 PM
04/24/17 01:37 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
Looking forward to having one soon smile
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293729
04/25/17 10:18 AM
04/25/17 10:18 AM
moparx Online content
moparx  Online Content
so this means a guy can now use an RE transmission without having to use the associated computer electronics ? if so, that would open up the donor choices a bunch.
beer
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293756
04/25/17 11:24 AM
04/25/17 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
cool stuff John!
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: moparx] #2293799
04/25/17 12:45 PM
04/25/17 12:45 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
beer
yes that is what it means. You can manually shift to 10,000 RPMs if you want. You will have to program your PCM to a 5 speed stick ( non automatic trans ) so you have no check eng light issues.
This also means, you can install any RE transmissions in your older Mopar and no PCM is needed.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2293952
04/25/17 04:41 PM
04/25/17 04:41 PM
GEORGIA
barracuda7199 Offline
GEORGIA
beer
Does it still use a lockup converter? This is an amazing product! Only thing we need now is a BB case!
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: barracuda7199] #2293986
04/25/17 05:18 PM
04/25/17 05:18 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I will have one for a lock up and one for a non lock up.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294026
04/25/17 06:42 PM
04/25/17 06:42 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
now that will be AWESOME, I have 518 in my street strip 512 68 Charger, right now I have a switch for OD & one for lock up, it would be nice to have 4 gears on the shifter & a Trans brake
LBA ?
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CSK] #2294179
04/25/17 11:21 PM
04/25/17 11:21 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I will have the valve bodies ready by the summer.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294391
04/26/17 10:51 AM
04/26/17 10:51 AM
now a really stupid question. any chance of a kit for us do-it-yerselfer's that like to save a buck if possible ? or maybe just a manual valve body kit without the brake ?
beer
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: moparx] #2294453
04/26/17 12:33 PM
04/26/17 12:33 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
beer
the ONLY way that can be done, is if there is no neutral,
Shift pattern would be:
P
3
And I am not sure if I want to go there.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294457
04/26/17 12:38 PM
04/26/17 12:38 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I wouldn't go there.
Now you have me thinking about going to an a500 vs going back to a 904 from a 727.
Any idea on the weight difference between a 500 and 727 vs a 904 with a gear vendors. I wouldn't mind an overdrive but I don't have much interest in a gear vendors unit either. Hmmmmm
68 Barracuda Formula S 340
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294488
04/26/17 01:45 PM
04/26/17 01:45 PM
mopar65 Offline
mopar65  Offline
Thanks for explaining it to me John.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294536
04/26/17 03:32 PM
04/26/17 03:32 PM
Guitar Jones Offline
I'm going to think long and hard about this for my diesel truck. I've been tossing the idea around for quite some time. Just need to figure out a shifter for it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: CRT] #2294538
04/26/17 03:41 PM
04/26/17 03:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Thats' cool. Does it still support a lockup converter? Would it work in a 48RE transmission?
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: Guitar Jones] #2294573
04/26/17 05:14 PM
04/26/17 05:14 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Any aftermarket shifter will work.
Re: CRT 500 518 618 trans brake reverse manual VB TESTED [Re: 451Mopar] #2294575
04/26/17 05:15 PM
04/26/17 05:15 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Yes & Yes. You will have to tune your PCM for a manual 5 speed stick so no check eng light comes on when the wiring will not be used and or plugged in.
